Weight of filled tires
   / Weight of filled tires #21
Both of my tractors have their rear tires filled, and the UTB has the front ones filled also. They are both filled with calcium. With the proper water/calcium ratio, you will never see your tires freeze over in the coldest temperatures, ever. The down side is the corrosive effect it has on metal...if you start to get a leak somewhere. It is imperative that you use an inner tube. Never direct contact with the rims. You may get a good shock at the price of inner tubes. They will jack the price by about 50%. Tire ballast greatly improves your traction, and stability. The tractor feels way more "solid". Follow the charts recommendations as per needed gallons. It should fill your tires about 2/3rds.
Rim Guard is pricyer, but you have the corrosive issue eliminated, and you may get away from using an inner tube.
Some drawbacks about filling tires: the moment of inertia will be more vs unfilled ones. Meaning more HP needed to get going, and greater breaking distance/resistance as well. Your max road speed could also drop. But I will qualify those as minor, as a tractor is a working machine not a show toy.
   / Weight of filled tires #22
I have all 4 of my tires filled with Rim Guard. Pricey but I though it was worth it.
   / Weight of filled tires #24
All the tractors here are old school with tubes os it is just plain old water in there.
Another reason why I have come to like using old tractors.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Yamaha Rhino 450 (A57149)
Yamaha Rhino 450...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
John Deere 950 Tractor (A57453)
John Deere 950...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
