Weight of filled tires
   / Weight of filled tires #21
Both of my tractors have their rear tires filled, and the UTB has the front ones filled also. They are both filled with calcium. With the proper water/calcium ratio, you will never see your tires freeze over in the coldest temperatures, ever. The down side is the corrosive effect it has on metal...if you start to get a leak somewhere. It is imperative that you use an inner tube. Never direct contact with the rims. You may get a good shock at the price of inner tubes. They will jack the price by about 50%. Tire ballast greatly improves your traction, and stability. The tractor feels way more "solid". Follow the charts recommendations as per needed gallons. It should fill your tires about 2/3rds.
Rim Guard is pricyer, but you have the corrosive issue eliminated, and you may get away from using an inner tube.
Some drawbacks about filling tires: the moment of inertia will be more vs unfilled ones. Meaning more HP needed to get going, and greater breaking distance/resistance as well. Your max road speed could also drop. But I will qualify those as minor, as a tractor is a working machine not a show toy.
   / Weight of filled tires #22
I have all 4 of my tires filled with Rim Guard. Pricey but I though it was worth it.
   / Weight of filled tires #24
All the tractors here are old school with tubes os it is just plain old water in there.
Another reason why I have come to like using old tractors.
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
2019 CATERPILLAR 259D3 SKID STEER (A60429)
2019 CATERPILLAR...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A60432)
UNUSED RAYTREE...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
UNUSED SDLANCH 20'X20' HIGH END CARPORT (A60432)
UNUSED SDLANCH...
