Welcome to my Nightmare!!!!
   / Welcome to my Nightmare!!!! #311
Eddie,
I ment to ask if you added up all of the costs for your overhaul what would it total? I assume that you have saved a few thousand $ by doing it yourself.
   / Welcome to my Nightmare!!!! #312
Eddie,
   / Welcome to my Nightmare!!!! #313
Congrats Eddie. I too am going to miss reading this thread. Now finish that lake and keep us updated on the progress. I was enjoying the lake thread also because I will be doing the same thing within a year or so.
   / Welcome to my Nightmare!!!! #314
   / Welcome to my Nightmare!!!! #315
Another great job Eddie. You are truly a "Jack of all trades!"
As for breaking it in... don't be afraid to use it. Varying your RPMs is your best bet. And as mentioned before... an oil and filter change after about 50 hrs.
   / Welcome to my Nightmare!!!! #316
The nightmare continues. /forums/images/graemlins/confused.gif
I put the air filter, muffler and other assesories back on today, then put away my tools, got some water and tried to start it.
Nothing.
The dash lights all came on like normal, but nothign else is happening. I have a couple saftery features that wont let the engine start if they are not in the correct position, but that's not it. They ARE in the correct positions.
No click from the starter.
No noise at all.
No power is getting to the starter.
It's just like on a CUT when you try to start the engine when the PTO is still in gear.
I'm sure I did something, but for the life of me, I'm stumped.
Eddie
Nothing.
No noise at all.
Eddie
   / Welcome to my Nightmare!!!! #319
Check from the ignition switch to the starter. It sounds like you might have knocked a wire loose or cut one of them. You might also check your battery terminals and cable ends, they might be corroded enough not to let a full draw from the batteries. If you have a battery checker you might check and see if you have a low or dead battery. One of the two batteries could be down and one battery would not be able to spin the starter.
Thanks for sharing your rebuild, good job!
   / Welcome to my Nightmare!!!! #320
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
Ammco Brake Machine (A53424)
Ammco Brake...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
1 pallet of pipe (A53117)
1 pallet of pipe...
