RobJ
Elite Member
</font><font color="blue" class="small">( Do you still have your old rod and main inserts laying around? If you do look on the back side of them and see if there is a "std" or ".010" stamped in them. )</font>
This would be a good place to start. With that sort of drop I'd be concerned. Technically it's ok but that's a huge difference and the only place it you affected it is in the rod bearings. If something got in the oil pump it could do this, reduce flow and pressure, most any other blockages would cause an increase in pressure. Look on the block and see if you can move the oil pressure gauge to another oil galley, might just have a plug(bolt) in the hole. I'm going to guess the oil pump is on the front so if the pressure at the front of the block is higher than the rear then you know you have something in between.
I'd probably also start with tossing on a new oil filter just in case.
