Welding cast aluminum....
   / Welding cast aluminum....
Thanks fellas! I gave JB Weld a try.... I'll give it 24 hours & if it fails I'll bite the bullet & replace...
   / Welding cast aluminum.... #12
Good luck! Structural Adhesives can be amazing. As mentioned, 'clean' surfaces are paramount. What I mean by 'clean' is you need to apply the adhesive to a high energy surface. All oxidation, mold release, oils, etc. must be removed and then the adhesive applied soon after... before oxidation lowers the ability of the metal to react to the adhesive.
   / Welding cast aluminum.... #14
The dangerous solvent in brake cleaner is " tetrachloroethylene"... IF brake cleaner does not contain " tetrachloroethylene" its pretty safe... Tetrachloroethylene when exposed to heat (MIG/TIG) it converts top phosgen (nerve) gas... Most brake/carb cleaners no longer user tetrachloroethylene, but read contents label on can to be sure...
Dale
   / Welding cast aluminum.... #15
Dale
My red can CRC Brakleen has the tetrachloroethylene but the green can CRC Brakleen does not. My LPS and CRC contact cleaners and the gumout carb cleaner does not list tetrachloroethylene either. Good info to know Dale.
   / Welding cast aluminum.... #16
Welding wouldn't be a problem for that repair and what I would do. If you think you might have to weld it anyways I wouldn't use job weld or an epoxy first, just makes a lot more work to weld.
Kubota castings are very nice and typically weld easily, I've done a number of repairs on trans cases in large trash trucks, very dirty and not fun but doable.
Acetone is my my cleaner of choice but the GREEN crc brakeclean will work also as it doesn't contain chlorine or the other nasty stuff.
Give you an idea of how dirty, this is a picture of a repair from where the pto shaft came appart and smacked the trans case cracking it. 1064053090.jpeg
   / Welding cast aluminum.... #17
Back in the old days of my refrigeration career (1950+) we had an aluminum brazing type alloy. It was low temp, had its own flux and could be used on any aluminum alloy and even aluminum to copper, bronze, or brass. We carried in the truck it to repair aluminum evaporators and aluminum to copper connections which were becoming popular. It was our emergency product for such cases. Need to google that and see what comes up.
Ron
   / Welding cast aluminum.... #18
There is still something similar out, even have a few sticks of it for weird non ferrous material that doesn't respond to welding well. Pretty tough stuff, it has its place.
Ron
   / Welding cast aluminum.... #19
Basically a hot rub on solder (read instructions for use) .... Don't see it as a repair....
Dale
Me either, structurally.... but just to stop it from leaking?
I'd try that before spending 1200 dollars
   / Welding cast aluminum.... #20
HTS 2000 works plenty good for most light duty repairs
HTS 2000 Aluminum Repair - YouTube
Worked pretty good for me on a couple repairs before getting a good sized AC tig welder
Not sure if it is the exact same product Harbor freight sells
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
