Welding round tube...Help please
   / Welding round tube...Help please #21
I bought the Harbor Freight jig before I bought the jig I listed above. It fell apart on the first hole/cut. The bushing come completely out and it was not worth fixing. I returned it.
Cary:cool:
   / Welding round tube...Help please #22
Sandlot said:
I have been thinking about this little tool. Anyone have one?
Harbor Freight Tools - Quality Tools at the Lowest Prices
I have one, and for the money, it is hard to beat, but as with most hf tools, it has its limitations. the bushing material can wear quickly, and I have heard some people mention that their tube vise is not centered with the madrel for the hole saw. I have used mine quite a bit building bumpers and cages for jeeps, and have no complaints for the price. for more $$$, better units are available. Like the bandsaw blades, I highly recommend a good quality bi-metal holesaw. use a low spindle speed, and some cutting oil. too much or not enough down pressure on the saw while cutting will shorten the life of the cutter.
   / Welding round tube...Help please #23
cityfarma said:
Thanks, I will give it a try. Just looks like it is a lot of work to get a good fit.
Cityfarma
It always is. It usually takes a lot longer to prepare for the weld than to do it. :D
   / Welding round tube...Help please #24
You might get some insight what i and others discussed in this thread:
http://www.tractorbynet.com/forums/build-yourself/105561-building-dirt-buggy-1.html
look at this photo: http://www.tractorbynet.com/forums/...6579788-building-dirt-buggy-08082007-001-.jpg
I dont really have time to proceed with the fun projects: First need the road sweep to put back to use, the grader blade and the straw bale chopper. Oh, and i need new brakes on my tractor, as well as some oil leaks that need attention.
(i'm excusing myself before people start asking when i post more progress :D )
   / Welding round tube...Help please #27
weldingisfun said:
Great info. Thanks.
:D
What if instead of a "T" joint, I want the notched tube at a 15* angle with my first 1.75" tube???? You must start with your base angle, which was 28* for 1.75"(remember above), and subtract 15* from one cut, and add 15* to the other cut to form a perfect notch. So now I must make a 13* cut and an 43* cut with the point centered on the tube. Perfect coped joint, with no grinding.
remember most tube (if new) has a line/seam drawn down the side that can be used as a "centerline" when makeing the notches. makes things that much simpler to aim for the "center".
   / Welding round tube...Help please #28
schmism said:
:D
Good point.
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
204158 (A57193)
204158 (A57193)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Mini SUV (A59231)
Mini SUV (A59231)
