We dug a well this week and had major cave in problems. at about 16 ft we appeared to have about 3 ft of water in bony gravel and decided to drop in the 2 ft dia concrete pipe casing. while setting the second pipe we had a major collapse that trapped and partly filled the first pipe. We added the 3rd pipe and backfilled what hadn't already caved in. Unfortunately, when I pumped it, we have less than a foot of water, so I'll have to deepen it either with an auger, long handled spoon shovel, lever operated clam shovel or drive a point. We'll try driving a point first as it's the easiest and we're already at the water table.
I'm just throwing this out for consideration as I won't need to try it because I shouldn't have to drive it over 5 or 6 ft and have access to an air powered post driver if necessary.
While researching and thinking about point driving, everyone that drives wells by hand comments about the huge amount of labor involved in picking up and dropping the drive hammer/weight on the casing. Some people run a rope attached to the hammer, through a pulley on a tripod over the well to pull up and drop the weight by hand. So I got thinking, if you rigged up a large spool on the outside of a rear tractor tire rim, then jack up the tractor on that side and block the tire off the ground, run the rope under the spool and snub it possibly to the front axle or other immovable object, then when the tire rotated, you'd have an up and down action very similar to the old cable well drillers. You'd just have to pay out rope as the casing went down and be 100% certain that the rope couldn't snag on a tire lug or something and wind the rope, tripod, hammer and all around the wheel.
Just a thought but might be worth trying.
Smiley
