Well pump cycles too much
   / Well pump cycles too much #1
Pilot
Veteran Member
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
After just a little water flow pressure drops from 65 to about 40 then the pump comes on and in a few seconds pressure is back at 65. If flow continues, the cycle continues.
What's up?
How to check the problem?
   / Well pump cycles too much #2
Your pressure tank. Google "checking water pressure tank". It easy to do.
   / Well pump cycles too much #3
Short version: Your pressue tank is water logged (lost most of its air bubble), drain tank and air up to 2psi below your cut-in pressure.
   / Well pump cycles too much #4
ditto turnkey4099. Been there, fixed that, straight forward fix.
   / Well pump cycles too much #5
Also if you do not correct the rapid cycling it will kill the pump motor. I went through this same problem two days ago, having a tire pressure gauge that was way off made it hard to correct the problem. I shut off my well and drained off the pressure, aired my blader tank up to what I thought was 28 pounds which would be two pounds under my 30 pound cut in pressure and it was worse then when I started , I started letting air out and it would get better so I stopped and went for a new air gauge, the new gauge read 43 pounds and after correcting it back to 28 pounds it was perfect. My tank and well was new two years ago after the last time it started hammering and I let it go, that ended up being a ruptured blader tank. Sense then I have to correct my pressure on the tank once a year.
   / Well pump cycles too much #6
You have a leak some place. Turn off water between the pressure tank and the house to see if the leak is there. As already suggested check the pressure tank.
Check out this site: Guide to Water Tank Problem Diagnosis
If this does not fix the problem you have a leak in the line from the pump to the pressure tank or the check valve at the pump is bad. One way to check if it is between the pressure tank and the pump is to install a check valve in the house just before the pressure tank. NOTE if this stops the cycling it is just a temporary fix because while the line is leaking water it is taking on air, so when you turn on a faucet air and water will come shooting out, so be prepared. Are you seeing any wet spots in the yard? If not there is a good chance the check valve that is on top of the pump is bad.
This needs to be fixed to avoid burning the pump up.
   / Well pump cycles too much #7
You have a tank problem. And if the pump comes on when no one is using water, you either have a leak or a bad check valve as well. If the pump only cycles WHILE you are using water, then there is no leak and the check valve is good, and only the tank is a problem.
The diaphragm in a tank bends back and forth every time the pump cycles. So called normal cycling every minute or two will break the diaphragm, just like bending a wire back and forth 100-300 times per day. Then the air gets out of the diaphragm and the pump starts cycling every few seconds instead of every minute or so, and the pump/motor is the next thing to go.
Air doesn't normally get out of a diaphragm tank on its own. Lots of cycling can expedite the loss of air as well as the loss of the diaphragm itself.
   / Well pump cycles too much #8
There are two kinds of tanks. The steel tanks have the water inside the plastic bag. The fiberglass tanks have the water outside the plastic bag. With the steel tank if the air pressure gets too low the water pressure in the bag will rupture the bag and you have your problem. With the fiberglass tank if the air pressure gets low the bag just collapses farther and it's not hurt. I replaced my defective steel tank with a fiberglass tank 16 years ago and haven't had any more problems.
   / Well pump cycles too much #9
If your tank is bad & you need to replace, go with the largest you can fit in the space if you can afford it. The larger the tank, the longer between pump cycles & the more steady your output pressure (also, the more water you are likely to have available during a power outage).
Nick
   / Well pump cycles too much #10
As an added tip: The little pipe the pressure switch sits on is prone to plugging up if your well pumps any silt at all (Mine used to pump a lot of it). That results in the problem of the switch not reading the true pressure to the point that the pump will be slow to kick on when it should and equally slow to shudt off. Results in both over and under pressure conditions. I replaced my pressure switch wiring with enough slack that I can unsrew it without disconnectin wires.
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
