Well Pump Expansion Tank
   / Well Pump Expansion Tank #41
That is the pressure valve ( like a bike tube air valve. The cap pops off and if you look at the electric pressure switch the air pressure is set at 2 lbs less the the cutoff pressure. You can use a tire pressure gauge to check the pressure. If you believe that your water pressure is good at the sinks, then leave it alone.
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
