gwstang
Platinum Member
There has to be some kind of a secret to adjusting the turnbuckles on the lower arms!
On the L2501, I removed the finishing mower as I am done with it for now and put the bush hog on...or tried too. I adjusted some on the turnbuckle on the right side as it was rubbing on the inside of the right tire. Almost impossible to do when the implement is on and in somewhat of a bind. I slid the right side arm off the pin and adjusted the turnbuckle and could not get the arm back on the hog. I fought with that thing for about an hour adjusting and pushing the hog around with a pry bar. I finally just removed the vertical adjusting rod on that side and then could do the turnbuckle. Re-adjust the vertical rod and then it was ok. Is there an easier way to adjust the turnbuckle with the implement attached? Not much room to do anything with one of those. btw, it is adjusted for now so there is no bind, but I do not wish to go through that again with the next implement change. I am use to the old Ford 8N that I have and it uses stabilizer bars to hold the implement where it won't hit the tires. Much easier to use. I am not in love with the turnbuckle type right now. ugh! :confused2:
