Well water has super-fine sediment
   / Well water has super-fine sediment #11
Precisely the sort of reply I was hoping for :)
Do you recall how much sediment you had in general? Was your water cloudy at all, or was the sediment heavier?
If I fill a bucket from the spigot next to the well (unfiltered), I get cloudy water which if let sit will settle out, about half the time. There's bursts of clear and bursts of cloudy, which makes me wonder about the sides of the well.
It's been very long since we ran well water at that house without the filter but, as I recall, we would get particulates that settled out and were visible in the bottom of the water glass but the water itself was only mildly cloudy. The taste was fine but rings built up fairly quickly at the toilet water level and in the bottom of the bathroom sinks. We had the house custom built and lived there for more than 20 years before selling. We had to have the well pump replaced once during that period and, while they had the pump out, they removed about 4 feet, or so, of scale, fine gravel and particles from the bottom of the well. As the water tested pretty hard we also added a large water softener which also automatically charged and backwashed on a schedule. Other than adding softener crystals periodically, replacing the empty chlorine pellet container with a new one every couple of months, and changing the filter sand once as I said above the system was very much a set and forget kind of thing. Unlike a previous poster, we experienced no loss of water pressure during system operation and the filter backwashed itself weekly.
   / Well water has super-fine sediment #12
Make sure your well pump wasn't set too close to the bottom of your well.
I'd sure get a well inspection and a water analysis done to find out what this stuff is.
   / Well water has super-fine sediment #13
It usually takes me around six replies before I get one I like. You got lucky on number seven. That's close enough. :)
   / Well water has super-fine sediment #14
At our old house we had a ton of iron. We used a system similar to the above. It had two tanks though. I cannot find a link quickly for it. It back washed periodically like a water softener.
Only issue was it really killed the water pressure.
No water system, no matter if pumping straight from the well, through an aerator tank, or even with filters should ever lack for pressure in the house. You just need to turn up the pressure to make up for the pressure loss through the filters and stuff. It is your water system. There is no need to put up with low pressure. You just have to make it happen since it is YOUR water system.
   / Well water has super-fine sediment #15
Yeah I don稚 live in that house any more:). House we are in now has multiple filters and water softener and has plenty of pressure.
   / Well water has super-fine sediment #16
I installed a similar system on both my daughter's and our house. 1" in and out.
No restriction when it was new, but the flow slowed down after 6 or 8 years. My daughter's plugged completely.
I've been hoping to find somebody to reload the media. I haven't found much online about what media to use or how to reload it.
   / Well water has super-fine sediment #17
As mentioned, raising the pump up might resolve. Too many folks set pumps too far down. If in a casing then the bottom of the pump needs to be above the screened area (a good foot or so).
Might be that the surrounding area around the bottom of the well/screen is just too packed up. I blew out a lot of crap out of my well (only 38' deep) when I rehabbed it: I'm hoping that it's not something I need to do again- after 5 1/2 years I'm not seeing any signs that I have a sediment/silt issue (my pump might be set high enough to escape any such problem, I don't know for sure).
Might be worth it to get a well person out and have them run a camera to find out.
jrsavoie, for all you know someone could have put in the wrong media to start with. No way to know for sure what media to use w/o having water testing done. I'd think that a backwash filter ought not plug, that plugging would be because there's not enough water flow for proper backwashing (and rinsing): different media require different flows- heavier media requires larger flows.
   / Well water has super-fine sediment #18
It would sound like clay particles which can remain in suspension for a long period.
Decreasing the well flow rate, if possible, may help. Floculation, as already mentioned, may be one of the better methods of removal but the treatment system may be difficult for a household to maintain.
[video]https://www.google.ca/search?q=clay+particles+in+suspension+test&client=safari&hl=en-ca&prmd=ivsn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjPzM2mrcLeAhWoY98KHTeRA4UQ_AUIEigB&biw=1024&bih=671&dpr=2#imgrc=s0LBEYEkp1NVJM[/video]
   / Well water has super-fine sediment #19
My daughter has town water. She is at the end of a dead headed line. Her water is the worst I've ever seen.
It'd be nice to find somebody to reload the media. Haven't found anybody that doesn't want to sell a whole system yet. Or to find instructions on how to do it myself. I can't believe it's rocket science
   / Well water has super-fine sediment #20
We had a very fine particles in our water. Most filters would be clogged within a few days.
Under advice I installed a swimming pool filter (had to make adapters to match 3/4" plumbing) and that solved our problem.
The pool filter uses a fine mesh set into a plastic tube.
Generally I can go 3-4 months B4 needing to clean out the particles. Low pressure generally is my indicator.
I contemplated creating a 'back flush' setup but since it is only a 3-4 month event I opted not to.
I do keep a plastic bristle 'bottle brush' nearby to clean out the filter.
Naturally I installed shut off valves B4 and after the filter for easy access. Also a bleed off valve on the bottom of the filter housing.
Works great going on 20 years now.
Also have some 1/2 dz client/neighbors set up the same way.
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
