Well Water Issues, Again.
   / Well Water Issues, Again. #31
Well,if it comes straight up outa ground,than it should be pretty simple to rig it up,not no spring expert,,,,but you goota dig down and contain it under ground,if it comes up instead of out the side of a hill like the ones I talked about,maybe it would even be simpler? dig down and your cistern goes over it,,or maybe a small cistern so's you can clean it out,,that leads to a bigger cistern,where you store the water and put your pump? if you can make that first one so's it collects any mud and such,,all the water going to main holding cistern should be clean.....they make these big plastic water tanks,some real big,,but they have small openings I think,,be hard to clean,,they make concrete ones too with a man way,like a septic tank,,,for your first tank,,maybe a big dia. plastic culvert type pipe,,,with some kinda lid rigged up on top,,drill holes in sides,,make 1 inch over flow at top,,gravel around it,,,bet if you did a search on internet for springs you would find all kind of ideas,,,,,but you'd still have to pump it to your home unless it is uphill from your home,,,but that should be doable,,,just need to talk to somebody who knows how big a pump,plus an electrician,,,how far is it and how much lower is it than your home? thingy
   / Well Water Issues, Again. #32
At my father in laws cabin we used one of those sump pump pits from HD
some 4" pipe and filter fabric fed to a new horizontal oil tank with some extra fittings welded in then 1200' if poly pipe down the mountain to cabin had about 75 psi at cabin we let it trickle all winter to keep it from freezing
tommu56
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2015 FREIGHTLINER...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
