WellWater and AIR>GRRRRR
   / WellWater and AIR>GRRRRR #11
Chopped,
If I read your original post and post #9, you have 2 check valves, one down at the pump level and another at the pressure tank?
Assuming that your system does not cycle when no water is being used, then I would suspect that the check valve at the pump level is leaking. That would allow the 130 foot column of water to leak back into the well after the pump shuts off. You may have a small leak in the pipe from the check valve on the manifold by the captive air tank down into the well. That would allow air to fill into the pipe going down into the well. When the pump starts it forces this air into the system. Even if there are no leaks, the atmospheric pressure can at most support a column of water about 32 feet high. Any dissolved gases in the well water will come out and a great deal of water vapor as the water level in the pipe going down into the well drops and distance from the surface to the water level is greater than 32 feet. Granted the water vapor will pretty much condense back into liquid but the un-dissolved gases will stay un-dissolved as the water is pushed into the system (e.g. the pressure tank and faucets).
Can you see or hear any leaks in the well casing when the pump is running? If the pipe going down to the pump has leaks in it it will most likely be near the static water level.
gordon
I just went through something similar with the pitless flange. I 'assumed' these castings are all a standard size. They are not. When I finally compared them side by side, there was enough difference in them that the new one would not seat properly in the saddle. Only three times in and out of the casing to figure this out.....
I hear ya. I asumed they would be very similiar, thats whay I had to replace th complete unit. And the new one has an 'o' ring in them as opposed to my original that had the leather gasket 'ring' Ive read a few places where the new gaskets have 'blown' out.I dont kow if they mean they actually blow to pieces or that they wouldnt seal.It is possible that it isnt sealing as it should.I havent taken it back out yet, but I did screw onto it and wiggle it a bit hoping it might seat.
You said three times in and out. what did you finally do to get it to seat?
Chopped,
gordon
Yes your correct on the check valves.Of cource the one on the pump is original and is as old as the pump ,but the one closer to the tank.(on the manifold) is from 1980 so I do wonder if maybe thats at fault.the way its set up, i could add a new one just before it and have the two of them right together.I could see if that makes a difference.Im assuming having two in a row would be a problem. but im still not confident that the pitless saddle is sealing as it should.So one thought is if it isnt, and the check valve at the tank is the least bit weak, then the two problems could be working together.?
As far as the leaks, nothing obvious....when its all at rest i can see a very slight movement of the water surface. but water does come in and drop onto the surface..so that might not be from a leak above in the water.
And when it kicks in I dont see any 'spraying' of the water .So this leak must be very very small.
its could be so many things and hard to pinpoint for sure.Im bothered that it was fine for the two weeks or so and seems to have returned. but not quite as bad.
gordon[/QUOTE]
Am i right to think if the pipe going down had a leak it would probably be above the static level?I consider maybe pulling it and cutting it off and run it shorter and then add back onto it..
   / WellWater and AIR>GRRRRR #15
most submersible pumps using the foot or internal pump check valve will only cycle when water pressure is released from the pressure tank and flows out. now if you have a 2nd check valve between the pump and the pressure than then the situation could happen if the pitiless adapter or pump foot check valve leaks and lets the vacuum pull at the pitiless and suck air in at that point.
Most well pumps around here dont have that extra / 2nd check valve so pressure from the well tank is kept against the pitiless and at the well pump check valve so there is less likely of a leak. now if there is the pump will cycle on & off regularly when you are not using water. one way to check this is to run water till well pump is on let it finish running to fill up to the pressure switch shutoff and then kill the circuit breaker to the well pump. check the pressure (should have functioning pressure gauge at the well tank on the water line some have on on the air pressure side of the bladder too. ) wait overnight and check the pressure if it is down then you have a leak in line someplace between the pump and the facets.
often there is a shutoff valve between the pressure tank and the well head pipe this would be closed to check the leak between the pump, pitiless & that shutoff valve.
Mark
   / WellWater and AIR>GRRRRR #16
I had exactly the same problem as originally posted. Well driller added 5' of length to the well pipe and problem was solved. Water table dropped because of ? (my guess is a few new homes on the road and now some all day sprinkler systems running and a swimming pool being filled, etc.) .
but my static level has remained the same for all these years.
   / WellWater and AIR>GRRRRR #18
I finally put the old one back on. It had a small knick in the o-ring, but there was no way I was digging out the saddle fitting. If it's leaking at this point, it should spray water when under pressure. A flashlight on a tether will let you see what's going on.
good point im going to look further. BTW I looked at a new pitless at lowes and the box was opened, I looked at the o ring and it was slip, a piece was missing.Im not sure why? or if it might have been a return that someone had broken.Are the 'o' rings a common ring?
I suppose and wonder, If I wre to put a check valve in on the pitless adapter (inside end) that would give me an indication if its leaking back from the coupler or the hose leading down to the pump.
hmmm
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2013 RAM 4500 (A50323)
