Westendorf FEL
   / Westendorf FEL
I am pretty sure it needs stands. I unhooked everything but the hyd. today and put a set of jackstands under it . I backed away from the loader and it wouldn't stand buy itself. I didn't try tipping the bucket all the way. I think the loader was built in the mid 80's.
   / Westendorf FEL #12
Here is a link to the Operators Manual for the John Deere 520 and 540 loaders. Scroll down on the left side to section 35 and 45. Click on these to read the procedure for removing and attaching the loader. These should be similar to yours and hopefully will give you some ideas on how to make some stands. I will also post a link to the 542 loader. The stands for the 542 are probably easier to make, since they do not hinge. They are stored in the cross tube and pin into the stand brackets when needed.
Good Luck,
Russ
Loader Stands
   / Westendorf FEL #13
Good Luck,
Russ
Loader Stands
   / Westendorf FEL #14
See section 20 and 25 in this manual.
542 Loader
   / Westendorf FEL #15
542 Loader
   / Westendorf FEL #16
Better picture of the stands on the 542 loader.
   / Westendorf FEL #17
   / Westendorf FEL #18
One more.
   / Westendorf FEL #19
One more.
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
8x12 Custom Built Chicken Coop (A51573)
8x12 Custom Built...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
