What a Joke! GM and its latest recall.
   / What a Joke! GM and its latest recall. #71
We used to have an 18k pound, 40' motorhome powered by a 1991 Ford 460 cu. in. gasoline engine. If we let it sit without running for a month or more, I could figure on adding a quart of oil after the first 400 miles, and then no more between 3k mile changes until we let it sit for a month or more again. But that's the only vehicle I can remember adding oil between changes in the last 20 years or more.
   / What a Joke! GM and its latest recall. #73
alot of times when diesel 'makes oil' it is an umbrella seal in a pump or something similar. and it usually shows up fast too... foamy breathers and all.. not good at all.
soundguy
One of my Ford diesels had that problem. It's easy to diagnose. Just pull your dipstick and allow the oil to drip on a clean white paper towel. If she's got oil in the crankcase, the stain will spread rapidly outwards. If it's just motor oil, it won't.
   / What a Joke! GM and its latest recall. #74
Ever see the macho knuckleheads that let their trucks idle while they go into a convenience store or gas station? That's what can happen to those engines.
I've never understood that. Must be a "big rig, I've got a deezul" thing. I've had diesel pickups since '81 and I always shut it down when fueling. Definately doesn't make sense with the new trucks and the emissions equipment. All idling does is clog the DPF.
   / What a Joke! GM and its latest recall. #75
yep.. I've seen it make clear like a corona around the dark spot.
soundguy
   / What a Joke! GM and its latest recall. #76
Valve guide seals dried out from sitting. When you first drive it, they allow oil by, then after they get softened-up the oil won't go past anymore.
I think you're right. At least that's my guess, too.
I guess you know some of the emissions stuff on the newer Ford diesels causes them to put some diesel fuel in the crankcase. A certain amount (and I've forgotten how much) is considered "normal". My brother has sometimes had to change oil in his F550 a little more often than planned.:D
   / What a Joke! GM and its latest recall. #77
Even worse, when the pistons cool faster than the cylinder walls, there's more of a chance fuel will wash down the cylinder walls and fill up the crankcase causing premature wear on the cylinder walls. Lots of guys who idle constantly don't think their trucks burn any oil but they are, the crankcase is just filling up with diesel fuel, which replaces the motor oil.
Guy I know in my town has a 6L Ford and a 6.5TD. Everywhere he goes, he lets them sit and idle for 10-30 minutes while he flaps his mouth with anyone that'll give him the time of day. Besides the racket in the parking lot, how about the air pollution, waste of fuel and wear on the engine?
   / What a Joke! GM and its latest recall. #78
I hope it's not considered normal, because that's bad for the engine. That changes oil viscosity and causes wear. My guess is he has leaking injector seals, or he has the idling habit, too.
   / What a Joke! GM and its latest recall. #79
and how about them injection pump-less setups.. weird..
soundguy
   / What a Joke! GM and its latest recall. #80
So my seven three won't last as long if I let it idle 12 hours a day?
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1300 (A58374)
1300 (A58374)
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A58214)
2012 TROXELL...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
