/ What and how do you heat your home and possibly shop during the cold winter months??
#41
5030
Rest in Peace
- Joined
- Feb 21, 2003
- Messages
- 28,967
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
The old style corn stoves like the long gone Amazing Blaze used a circular burn pot whereas modern pellet only stoves don't and a multifuel unit like I have uses what is called a 'rouser' on the burn pot to 'stir the fuel. If you try to burn corn in a conventional pellet burner all you wind up with is a big hard clinker in the burn pot that cuts off the air supply to the fuel bed and has to be removed quite often.... and with true multifuel units you can adjust the air supplied to the burning fuel as corn not only requires more air but requires a higher ignition temperature as well. The two I own are actually what is referred to as gasifier units. The fuel bed actually combusts above the actual fuel and they have secondary air ports above the fuel bed for a more complete burn. Been fiddling with these things for over 30 years now and I've actually wore out 2 stoves.I had a friend about 20+ years ago that was a HVAC contractor but also sold the corn stoves. I thought it was a great idea. I've moved away and occasionally wonder about corn stoves. Iirc it was basically what today's "pellet" stoves are but I don't think they were around yet, at least in my travels.
I mix corn with the pellets to extract more btu's from a given amount of fuel. The drier the corn is, the better (and cleaner it burns). The off grade corn I get is at 9%RM which is way drier than normal field corn which is usually around 12%RM. Anything over 12 won't burn clean and causes a lot of soot to form. Only time I mix in corn is when it's really cold outside and windy and I only mix in about 1 part corn to 3 parts pellets and the pellets eliminate any corn clinkers that might form in the burn pot. When field corn burns it does what is referred to as 'carmelize'. That is the the meat of the kernel comes out of the husk and 'flows' and ignites, leaving the not flammable husk behind and it's the husk that causes the clinkers.I used to buy shelled corn pretty cheap from the Southern States Co Op to feed the deer in the dead of winter when we actually had snow cover (mid Atlantic region) . I'm thinking that between the ethanol business and the high commodity prices that have been created by Washington, it might not be so much of a savings today, at least at the retail level.
5030 you have a great connection. Why do you mix with pellets? Better burn?
Because the wood pellets ignite at a lower temperature than the corn, the pellets keep the fuel bed temperature high enough (with the addition of forced draft combustion air) to cause the corn to carmelize and burn.
Interesting to watch the process through the clear high temperature mineral glass window.
Problem with burning field corn is, it's a regional thing and where you live, I imagine corn would be hard to get, plus it has to be below 12% or it won't burn properly so out of the field, field corn don't work as usually out of the field it's anywhere from 15-25% RM depending on when it's combined and the weather.
If my source of off grade seed corn somehow came to an end, I'd just run straight pellets as I don't want to be paying dry down fees on top of buying the corn.
Finally, a by product of burning corn is nitric acid so you have to be cognizant that nitric acid will not only eat up your stove but eat up the venting as well. Why towards the end of the heating season, I run straight pellets for a couple weeks, to eliminate any nitric acid vapor that might have condensed in the stove or venting is removed. Even though the venting is stainless steel lined it will still eat it up over time. I still get a certain amount of corrosion from it, inside the stove and burn pots.
Has it on last night on idle fire and got up this morning and shut it off as the house was at 74 degrees.
I run what is called a 'Therm Guard' on my central furnace thermostat that cycles the furnace blower for 5 minutes every 1/2 hour to distribute the heat throughout the house as the stove is in the greatroom and we have to move the heat to adjacent rooms as well.
