What are these brackets called ?
   / What are these brackets called ? #1
SARG
Platinum Member
Upstate New York
NH T1030- NH T1530 - 49G Brockway
I finished putting the deck & back onto the Carry All frame today and would like to put sides on it. I spotted the brackets shown in the picture from this forum but can't find them on the net.
Probably because I don't know what they are called. I've searched "square tube interlocking bracket" without success. I realize I could just by the 2x4 steel brackets but would prefer those shown.
Any ideas on what they're called ?
   / What are these brackets called ? #2
Are you talking about stake pockets. Your pic isn't verry good. It doesn't get much bigger when you click on it
Bill
Nope . The 2x4 brackets I mentioned are stake pockets. Those shown in the picture appear to be square metal tube where they have a male section that inserts into the interior of the adjacent piece.
I made the picture a little bigger.
   / What are these brackets called ? #4
Does seem to be something going on there with those stakes, but very hard to imagine what it is.
Do you think the lower parts are fixed to the frame, and the upper ends slide into the lower part?
Can you link to the original thread?
Did a search on "telescoping tubing" and it might be what you are looking for. ??
   / What are these brackets called ? #5
almost looks like an imitation of uni-strut.
   / What are these brackets called ? #7
i doubt you'd find those anywhere except the guy's garage that made them, if he made extras. looks custom fab to me. what thread did you find that picture in?
   / What are these brackets called ? #8
SARG- see if you can locate a place that specializes in trailer stuff; they often have all sorts of trailer hardware, including hardware for trailer sides. Around here we have a place called "Lucky's Trailers Sales."
They do have a website:
"Need Parts? We have them in stock and will deliver to all of Vermont, parts of New York, New Hampshire, Connecticut, and Massachusetts. We have parts for all makes and models of trailers."
I picked up some interlocking corners for my little trailer's sides from them. Couln't find them anywhere else.
You might even find similar items at a TSC store....
  • trailer w:sides.JPG
    trailer w:sides.JPG
  • trailer:sides.JPG
   / What are these brackets called ? #9
You could try using cut pieces of top rail from cyclone fencing. The sections slide into one another as the fence goes along. You can buy the pipe at the big box stores. Just an idea if you wanted to fab something yourself.
   / What are these brackets called ? #10
Hey, I recognize those! You are correct, I custom-made them out of two sizes of steel tube nested together, I think it was one inch on the outside and 3/4 on the inside.
To connect the inner and outer tubes, I drilled a couple of holes in each outer tube and then puddle-welded the two together.
Problem was, they didn't fit as tight as I wanted, so I wound up welding some thin washers on the smaller tubes to take up some of the slack. Maybe you can find sizes that fit together better. Here is a pic of the "nesting" end of the tube.
I have a thing against bolts sticking out to snag stuff, so I recessed them within the tubes. To attach the stakes to the wood, I drilled a 1/4 inch hole all the way through both sides and then enlarged the outer one to 5/8 so I could get the nut on the carriage bolt.
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
2003 Big Tex 10PI...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
