What are these connectors called?
   / What are these connectors called? #1
thegoulais
Compbellsport, WI
John Deere X584 and Ford F 1100 4WD
   / What are these connectors called? #2
They look like SAE ORB (O-ring Boss) in the valve and female swivel pipe where hose attaches.
depending on valve make also possible could be BSPP in the valve
   / What are these connectors called? #3
The male ends (in the valve) look like SAE also called ORB (O Ring Boss) the female ends to the hoses look like female swivel NPT (National Pipe Thread)
   / What are these connectors called? #4
too many look the same but different. remove them and take them to a hydraulic shop to match them up. will save a trip or two.
   / What are these connectors called? #5
From what I've read, disassembling and reassembling NPT induce leaks so personally, I bought different combinations of fittings and only used the one that I needed and returned the rest.
   / What are these connectors called? #6
While this is probably true I would liken it to the fact that you are more likely to have an accident driving your car than if you left it parked.
   / What are these connectors called? #7
From just a visual inspect I'd say that both post 2 and 3 had the correct answer.
As far as reusing them replace the O-rings (should be less then a dime each) and use a bit of pipe dope on the male threads.
   / What are these connectors called? #8
Yup, look like standard ole ORB fittings. No thread sealer required
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
49" X 58" TRAILER TAILGATE (A54756)
49" X 58" TRAILER...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
