What brand work lights are you running?
   / What brand work lights are you running? #21
The load on each switch is only 8 Amps so I will run a twenty amp fuse directly off the battery. Then I will tie each switch to the fuse. Then I will run directly to the lights with 14 or 12 gauge wire. The leads off the switch are only 18 gauge so I will trim them as short as possible. I am using heavier wire to reduce resistance in the wire to the lights. It is a bit of overkill but will reduce voltage drop. No need for a relay since I am not going through the Ignition switch. I like being able to turn on the lights independent of the ignition anyway.
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
Case IH Farmall 75C (A52349)
Case IH Farmall...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
