What determines hydraulic power?
   / What determines hydraulic power? #11
I am trying to find out if hydraulic power differs drastically with engine rpm on same size horsepower tractors. Is there maybe a "rule of thumb" that someone can share? What's everybody thinking on this?
With a PD pump when you increase the rpm the flow rate goes up. Means that you will be able to do more work with the end device.:thumbsup:
   / What determines hydraulic power? #12
The only rule of thumb is to put a pressure gauge in your hydraulic system, then max out you fel or other attachment look your machines output in psi @ different RPM
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
2013 Audi A6 AWD Sedan (A56859)
2013 Audi A6 AWD...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A57024)
2023 Kubota...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
