What grade gasoline do you use?
   / What grade gasoline do you use? #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
I was wondering what grade gasoline you guys use in your Robin engines?
   / What grade gasoline do you use? #2
I use regular in my 422. 500 hours and no issues. Would high test give me more power?
Bob RIp
   / What grade gasoline do you use? #3
Regumlar 87 in the Kohler. /forums/images/graemlins/tongue.gif
   / What grade gasoline do you use? #4
I have used high test(93?) since the Farmall and the old pick up truck prefers it...no problems with either.
   / What grade gasoline do you use? #5
In ALL my engines, for as long as I can remember, High Test, currently 93 in N J.
I'll do almost anything to give me quick starts ! ! ! ! ?
   / What grade gasoline do you use? #6
Pequeajim asked #839418 :</font><font color="blue" class="small">( Do you guys run regular or mid-grade in your Robin engines? )</font>
Tracdoc replied:</font><font color="blue" class="small">( <font color="orange"> Jim, per suggestion of Jack Robin in an older thread, I have been using premium (aka hi test) fuel plus a dose of lead substitute in my Robin engine. That cocktail was recommended to reduce the shutdown detonation. Didn't seem to do squat for that, but the engine has always run very well with that regimen..... </font> )</font> /forums/images/graemlins/smile.gif
   / What grade gasoline do you use? #7
I use 87 which is just regular unleaded here in OK.
I only have about 60 hrs on my 425 but have had no problems, I do have a little bit of a hard time starting if it is below about 20 or 25 degrees Farenheit. /forums/images/graemlins/mad.gif But thankfully that doesn't happen for any great length of time here. /forums/images/graemlins/laugh.gif at least not very often.
   / What grade gasoline do you use? #8
Been using 91 octane which is the highest we can get here in northern CA. Started using it early on to stop the "run-on" and backfires but I don't think it really helped much, if any.
Since I prefer to take my cans to be filled in the back of my pickup, and since that pickup has a chip and requires higher octane, it also makes it more convenient to fill the cans then continue on to put gas in the truck. Taking the cans to be filled in our SUV makes for unpleasant fumes inside.
Phil
   / What grade gasoline do you use? #9
I use regular (85) here in Montana. No problems so far.
PJ
   / What grade gasoline do you use? #10
Like Moss, I run 87 in my Kohler without problems.
2009 NISSAN Murano AWD SUV (A55758)
2009 NISSAN Murano...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
