What hydraulic motor to buy?
   / What hydraulic motor to buy? #1
schell2701
Craig,Co
John Deere
Hello,
I am looking to add a hydraulic motor to replace the pto drive line on my Krone Swadro 900 hay rakes. Krone tells me it takes around 40 hp at 540 rpm's to operate the rakes. Would any body be able to tell me what hydraulic motor will be able to do this? Thanks!
   / What hydraulic motor to buy? #2
Hello,
I think that there are people who can tell you what motor you should buy (I don't know), but my question, why would you change it to hydraulic driven instead of pto driven?
Thank you, Wilco.
We are going to start pulling our round balers behind the rake and need to utilize the pto drive line for the balers and still need to power the rake too.
   / What hydraulic motor to buy? #4
Wow, that should become a big machine! :thumbsup:
Maybe you can post a vid if it's all working?
Succes whit it, I hope there are members who can tell you what sort of motor you should buy.
   / What hydraulic motor to buy? #5
What kind of flow in GPM's do you have and what pressure is the relief valve set.
Your tractor develops only so much HP, to run itself and PTO HP. What one does not know is if the machine using the PTO is using all the PTO HP.
Question should be how much HP is required to run both machines.
One machine already uses 40 HP, so how much does the other machine require?
You say you are using 40 HP on the PTO. What is the rated PTO HP.
What is tractor HP? If it is at about 45 HP, then you are almost at your limit for HP.
   / What hydraulic motor to buy? #6
To operate at 540 RPM you are probably looking at a LHST (Low Speed High Torque) since most motors don't run at that low RPM real well.
Figure approximate motor size.
40 HP = 390 ft-lbs torque = 4670 in-lbs torque
Fluid motor size formulae:
(torque (in-lbs) x 6.28) / PSI = Fluid motor displacement in cubic inches per revolution
(4670 x 628) / 2000 = 14.67 CIR
figure 15% efficient so 14.67 * 1.15 = 16.9 CIR
figure inlet GPM at 540 RPM (16.9 x 540) / 231 = 39.5 GPM
This is just a starting point since you will have to know your actual operating pressure less the line losses so your pressure to run the motor may actually be lower.
Input HP to the pump GPM * PSI / 1500 = 39.5 * 2500 / 1500 = 66 HP
I used 2500 PSI as your system operating pressure and figure you will have 500 PSI line loss.
What happened to the days of ground driven rakes???
Roy
   / What hydraulic motor to buy? #7
Roy,
He is already using some or all of the HP for the other implement.
What we don't know is how much can be divided into the 40 HP. If one implement is using 20 HP, then only 20 HP is left to power the hyd motor on the other implement..
   / What hydraulic motor to buy? #8
when you figure out your available hp&flow as jj suggested go to whitedriveproducts.com, use the dist. locator, they have several motors that will get you done at lower flows and moderate pressures. but you got a little homework to do. max tractor hp,minus hp required to drive the other piece of equip. then you need to know the available flow and pressure and hp
Hello,
Thanks everybody for the response. I just found out I gave some wrong info for my question! I need a motor that operates at 450rpm. I will be running one of the units on a JD 2955 (85pto hp) @21gpm and 2320psi. The other unit will be behind a JD 7410 (105 pto hp) @26gpm and 2900psi. Hope this info can help figure this out.
   / What hydraulic motor to buy? #10
21 GPM pump using a motor displacement of 10.75 cu in= 451 rpm
26 GPM pump -----------------------------------13.4 cu in = 448 rpm
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55314)
2020 New Holland...
Booster Cables (A55852)
Booster Cables...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2017 MOROOKA MST300VD CRAWLER DUMPER (A52707)
2017 MOROOKA...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
