What is the next best 3/4 plywood when I can't get marine plywood?
   / What is the next best 3/4 plywood when I can't get marine plywood? #11
I had a couple of leftover sheets of 'exposure' grade plywood- intended to survive a limited time exposed before becoming the interior of a house. I used it in an exterior application, thoroughly primed with oil base primer then latex top coat. So far its holding up fine.
For a trailer that isn't left outdoors all the time I expect this would be ok.
   / What is the next best 3/4 plywood when I can't get marine plywood? #12
Have you checked to see if the lumber yards or box stores can order it for you? Menards carries 3/4" marine grade plywood in stock by us ($60 range) but I know there are no Menards close to you. It sure seems like the other box stores could order it for you at a reasonable cost.
Tried that several times, apparently if it's less than a truckload it's not worth their effort.
   / What is the next best 3/4 plywood when I can't get marine plywood? #14
When we lived in that area I used to get stuff at Barron's. It is a real lumber store, much better quality and selection than the homeowner places. I just checked their website, they have MDO plywood in 3/8, 1/2, and 3/4 sizes.
   / What is the next best 3/4 plywood when I can't get marine plywood? #15
Get a good sheet of plywood for cabinets. It will be great quality. It will not be rated for outside use, but with a couple coats of good paint, it will last forever. I drive by some every day that has been up for more than 30 years.
Ford Metal Tailgate Art (A55853)
Ford Metal...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2013 RAM 4500 (A50323)
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
