What is the spindle RPM for Grooming mowers?
   / What is the spindle RPM for Grooming mowers? #1
DocHeb
Michigan
New Holland TC40D Supersteer
What are the spindle RPMs for Rear-Finish Mowers and Mid-Mount Mowers, assuming 540 PTO speed? I can find tip speed in feet-per-minute, but can't find RPMs.
   / What is the spindle RPM for Grooming mowers? #2
If you know Tip speed in fpm the formula's pretty simple.
Tip Speed divided by (Blade Length times Pi divided by twelve)
If you have access to Excel the formula is.
B1/(B2*3.1416/12)
Where B1 is tip speed in FPM and B2 is Blade Length in inches.
   / What is the spindle RPM for Grooming mowers? #3
I think (don't hold me to this) that OSHA limits tip speed on mower blades to 19000 fpm.
All you then need is blade length to figure rpm.
Pooh Bear
Edited to change to correct speed.
   / What is the spindle RPM for Grooming mowers? #4
Don't try to go over the speed of sound at the blade tip ... nothing good will come from that!
Leo
   / What is the spindle RPM for Grooming mowers? #5
17000 fpm is approx mach .25
Mach 1 is the speed of sound.
Mower blades top out at around 19000fpm.
There is a post about this over on the attachments forum.
RE: Can Someone Explain Blade Tip Speed To Me Please
</font><font color="blue" class="small">( First Choice Groming mowers are: FPM is 13700 on the 4ft, 14100 on the 5 ft, 14200 on the 6 ft and 15300 on the 7 ft. At 540 PTO, Blade RPM is 3130 for the 4 ft, 2650 for the 5 ft, 2240 for the 6 ft and 2030 for the 7 ft. We have been selling this brand since the company started and have not had 1 failure on the quill assembly.--Ken Sweet
)</font>
Pooh Bear
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
24in pin on tooth excavator bucket (A56436)
24in pin on tooth...
golf cart electric (A55787)
golf cart electric...
Generac Power Systems (A57148)
Generac Power...
