What is the weight of fluid filled tires?
   / What is the weight of fluid filled tires? #11
G
According to the John Deer ballast calculator an 80% fill of 3.5 lb CaCl would add 104 lbs to the weight of your tractor. The HD bucket would probably add a few pounds but it is not listed in the calculator. These weights listed are with CaCl in the rear tires. Total is 3446 lbs including a 190 lb driver driver.
One flaw with that chart is that is subtracts 186lbs due to counterweight effect from the FEL...but that doesn't change total weight for towing.
   / What is the weight of fluid filled tires? #12
My old eyes could not tell from mudfarmers avatar what tires the tractor had on it. I assumed the 3005 had R4 tires on it. For 11.2 X 24 size the calculator shows 80% 3.5 lb CaCl filled rear tires add 213 lbs to the total weight.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A58018)
2015 UTILITY VS2RA...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
2013 Case 580 Super N 4x4 Extendahoe Loader Backhoe (A55973)
2013 Case 580...
