What is this out of?
   / What is this out of? #1
jcummins
Veteran Member
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Reworking a wood line need to the drive and unearthed thede things. What is that out of? 20180317_103847.jpg
   / What is this out of? #2
My long lost flux capacitor!
   / What is this out of? #3
Looks like clutch plates out of a automatic transmission.
   / What is this out of? #4
Yep a big old machine or possibly a big logging winch- although I’ve never been inside a big logging winch so that’s a swag.
   / What is this out of? #8
they look like skidder brakes or dozer brakes as previously mentioned.
   / What is this out of? #9
there some type of Wet friction plates, for either brakes, or power shift transmissions, or automatic transmission, (wet means they run in a hydraulic or transmission oil)
steels or disks of steel with teeth on them will fit between them and then a hydraulic piston will push against them putting pressure, and locking them together if enough pressure is applied, thus a clutch,
similar action is used as brakes,
the plates teeth lock in to one side, either the drum or the shaft and the steels lock in to to apposite,
and a piston when applied presses against them locking the shaft to the drum,
on an automatic transmission / power shift transmission, this is how the gear range is changed,
on brakes it locks a moving part to a stationary part, on clutches like in a dozer, it locks up the drive axles or releases them,
On some clutches there are planetary gears and they use a brake band, that stops the drumm from spinned and forces the rotary power to the out going shaft, in some transmission there is a combination of clutches that work the inside of the drum and some times the outside of the drum with a band, and depending on what clutches lock up is how the transmission shifts, or transmits power through the gears, to the drive axles,
2000 Chevrolet 3500 Express Passenger Van (A48081)
2000 Chevrolet...
2023 Chevrolet Tahoe FL SUV (A48082)
2023 Chevrolet...
2010 Cadillac SRX Luxury SUV (A48082)
2010 Cadillac SRX...
2019 Ford E-350 Super Duty Knapheide Enclosed Service Van (A48081)
2019 Ford E-350...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
CURTIS RS75D E25C ROTARY SCREW AIR COMPRESSOR (A50460)
CURTIS RS75D E25C...
