What is this out of?
   / What is this out of? #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Reworking a wood line need to the drive and unearthed thede things. What is that out of? 20180317_103847.jpg
   / What is this out of? #2
My long lost flux capacitor!
   / What is this out of? #3
Looks like clutch plates out of a automatic transmission.
   / What is this out of? #4
Yep a big old machine or possibly a big logging winch- although I’ve never been inside a big logging winch so that’s a swag.
   / What is this out of? #8
they look like skidder brakes or dozer brakes as previously mentioned.
   / What is this out of? #9
there some type of Wet friction plates, for either brakes, or power shift transmissions, or automatic transmission, (wet means they run in a hydraulic or transmission oil)
steels or disks of steel with teeth on them will fit between them and then a hydraulic piston will push against them putting pressure, and locking them together if enough pressure is applied, thus a clutch,
similar action is used as brakes,
the plates teeth lock in to one side, either the drum or the shaft and the steels lock in to to apposite,
and a piston when applied presses against them locking the shaft to the drum,
on an automatic transmission / power shift transmission, this is how the gear range is changed,
on brakes it locks a moving part to a stationary part, on clutches like in a dozer, it locks up the drive axles or releases them,
On some clutches there are planetary gears and they use a brake band, that stops the drumm from spinned and forces the rotary power to the out going shaft, in some transmission there is a combination of clutches that work the inside of the drum and some times the outside of the drum with a band, and depending on what clutches lock up is how the transmission shifts, or transmits power through the gears, to the drive axles,
2007 FORD F150 XL EXT CAB TRUCK (A51406)
2007 FORD F150 XL...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2016 CATERPILLAR 306E EXCAVATOR (A52705)
2016 CATERPILLAR...
2004 Jeep Liberty Limited SUV (A55853)
2004 Jeep Liberty...
