What kind of oil for a pressure washer pump?
   / What kind of oil for a pressure washer pump? #1
BANDAMAN
SE Iowa
Deere 318
My neighbor just came over and asked me what kind of oil goes in his gas engined pressure washer pump. Apparently, last fall, he asked one of his sons to drain the water out of the hose for storage, but his kid drained the oil out of the pump instead! The manual doesn't specify oil type, it says the pump is maintenance free and doesn't need servicing.
Any experts out there know what we should fill this thing up with?
Thanks for the help!
   / What kind of oil for a pressure washer pump? #2
I use a 10-30 in my 2400 PSI for what it is worth. I change it every year since it hold like 1/2 qt
   / What kind of oil for a pressure washer pump? #3
Northern tool sells a 30W pump oil and I have also seen a 15W-50 for pumps. not sure if any oil will work or if it needs to be special type for water pumps. if the machine is new I would use oil specific for water pump so as not to void warranty.
   / What kind of oil for a pressure washer pump? #4
Hope the pump didn't freeze and break.
   / What kind of oil for a pressure washer pump? #5
I'd call the Mfg. to find out since the manual doesn't say.
Thanks everyone for the help. He went to town and got what he needed. They had it running awhile ago, so I guess everything is ok. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Mike
   / What kind of oil for a pressure washer pump? #7
All our pumps state SAE 30 motor oil right on the housing. We use M-I-TM commercial units 3500 to 4000 psi.
   / What kind of oil for a pressure washer pump? #8
Mine calls for 30w non detergent.
   / What kind of oil for a pressure washer pump? #9
Mine says 30w Non Detergent for the pump only. Motor uses a different weight.
   / What kind of oil for a pressure washer pump? #10
My DeVilbiss pump calls for 30W non detergent. Must be a standard of sorts.
Tradewinds Power Unit (A50120)
Tradewinds Power...
WESSEX RMX500 LOT NUMBER 44 (A53084)
WESSEX RMX500 LOT...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
