What kind of shackles do folks use to hold rear tire chains on? I've tried regular "D" shackles, but the pins get all mushed if they're pointing out (the flat blade that you tighten the pin with), and I'm worried they'll cut into the tire if pointing in. The links are twisted, so I can't really get the shackles to lay flat on the tire. Also tried flush pin shackles that are tightened with a 3/16" allen wrench, but the pins work out and also get pretty mushed up. I've had to sawzall more than one off in the spring.
Any enlightenment from oldtimers who know is appreciated.
