Buying Advice What kubota is similar to 4400 or 4600 JD
   / What kubota is similar to 4400 or 4600 JD #1
msdmopar
Michigan
john deere 3320
I am looking for a jd 4400 or 4600 SIZE tractor and I am not fixated on brand, but would like to stick to Kubota or jd because of the two local dealers in my area. I need help trying to figure out what the same size and function tractor in Kubota is. I want as little electronics as possible, so not too new. 4x4 Hydro with front loader. If you give me a Kubota number to look at if you happen to know any differences between the k and jd that would be great. Thanks
Future backhoe capability too.
   / What kubota is similar to 4400 or 4600 JD #2
JD 4400 looks to be 98-2001, 35HP, 2900lbs. JD 4600 is similar age, 43HP, 3450lbs.
Kubota tractor list of sorts can be found here: TractorData.com - Kubota tractors sorted by model. Equivalents would be maybe an L3410 and L4300 or L4310 from looking at the data, but no idea if those were actually common models in your location.
   / What kubota is similar to 4400 or 4600 JD #3
   / What kubota is similar to 4400 or 4600 JD #4
jeffy,
OP stated he desires minimal electronics. That eliminates ALL 60 series kubotas.
Paul 2 submitted a post that actually offered valid assistance to the OP.
Great info, thanks.
I want to be able to do more work myself, without codes and modules etc.
   / What kubota is similar to 4400 or 4600 JD #7
   / What kubota is similar to 4400 or 4600 JD #8
L2501 is 2,500lbs or so. They rejiggered the engine to get under the 25hp emissions limits. So it will be as big of a machine as you will find new without a DPF & associated electronics. Everything else new will have a DPF & I think common rail injection.
   / What kubota is similar to 4400 or 4600 JD #9
I get the impression OP was looking second hand, about the same vintage as the JD 4400 or 4600. So we're talking around about 1998-2002 tractors, not current models.
I don't care too much about newer years as long as they don't have all of the electronic everything .
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
Uni-Carriers S1S1L15NV 3,000lb Electric Forklift (A55851)
Uni-Carriers...
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
16ft T/A Flatbed Trailer (A53424)
16ft T/A Flatbed...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
