JoeBuyer
Banned
- Joined
- Dec 11, 2011
- Messages
- 846
- Tractor
- L5450
RobertN said:Gas can last a long time. My comparison would be the 1941 Farmall A
The Farmall motor red-lined at about 1600rpm(again, from fuzzy memory)
After having that old tractor though, I bet that low rpm low compression motor would run forever, if maintained properly.
Yours is similar to the old Massey Perkins gas engines which ran at 2000 rpm. I would think a gas engine using a diesel block running at 2000 rpm at a much lower compression ratio would last "forever". The advantage that diesel has at that point is the fact that diesel is a lubricant and gas a solvent. Too bad none of us would live long enough to wear either of these out given proper maintenance LOL. Modern high revving gas engines are a different animal.
