~~~ WHAT"S BEST ~~~
   / ~~~ WHAT"S BEST ~~~ #2
It depends what weight you are carrying and the amount of tongewright your tow vehicle can take. The trailer with the wheels further back will transfer more weight to the tow vehicle.
   / ~~~ WHAT"S BEST ~~~ #3
I like the trailer with the wheels further back. Also depends on what type of truck you will be pulling with it. I agree with TOADHILL.
   / ~~~ WHAT"S BEST ~~~ #4
Like said before. I the wheels are more then 60% of the way back you will need a F-250 or equivalent for loads more than 7,000#.
Chris
   / ~~~ WHAT"S BEST ~~~ #5
LBrown59 - I totally saw something different than the other posters... Are you refering to the wheel position in relation to the deck (ie deck over vs lower deck with wheels exposed)? Or as already mentioned?
Brian
Thanks but I was refering to wheels placed under the deck VS wheels placed beside the deck.
Was wondering about the pros and cons of both.
   / ~~~ WHAT"S BEST ~~~ #7
the deck over trailers allow you to carry wider loads without it hitting the wheels.. BUT it could make it harder to load some items because of being higher deck and greater approach angle... I remember someone mentioning on a bumpy road their tractor kept slipping/sliding around on the deck..
The lower trailer offers the advantage of the sides keeping stuff from sliding off.
The deck over trailers (from the ones I have seen) appear to be much heavier built than the others.. This would give you a much greater capacity..
Good luck
Brian
1*the deck over trailers allow you to carry wider loads without it hitting the wheels..
2* BUT it could make it harder to load some items because of being higher deck and greater approach angle...
3*The lower trailer offers the advantage of the sides keeping stuff from sliding off.
4*This would give you a much greater capacity..
Brian
1*That's what I like about them over the lower trailer.
Example I just got an 8 x 10 storage building today and could haul it home on a deck over but not the lower trailer.
2*That's what i don't like about them compared to the lower trailer.
3*Removable sides could be added to a deck over.
4*Difference in capacity wouldn't be an issue as long as there was enought capacity to haul my BX23 on either trailer with loader and Bh attached.
   / ~~~ WHAT"S BEST ~~~ #9
Good luck
Brian
Actually, it would seem that way, but it isn't. The heavier built trailer will often have less carrying capacity. If you get two 14k trailers and one is heavy built, it will have a lower capacity for stuff on it. The 14k is load + trailer, so a heavier trailer = less load.
   / ~~~ WHAT"S BEST ~~~ #10
Deck over wheels is hard to load if you have a 3 point attachment. I prefer option/photo #1. Easy to load
   / ~~~ WHAT"S BEST ~~~ #11
Along with the what the other posters have said , the trailer with the wheels farther back will be easier to back up...I addition to being better mannered on the road if loaded properly (ie: less herky-jerky)
   / ~~~ WHAT"S BEST ~~~ #12
Also, with the deckover configuration, you can fork lift loads onto the entire trailer deck. With the other scheme the fenders block a good part (and serious load carrying portion) of the bed from fork access. I have the fender model and learned this when hauling brick/block for a project. But, as others said, the deckover is higher and may be more challenging to load low slung vehicles onto.
There is no right or wrong, just depends on what you intend to use it for.
   / ~~~ WHAT"S BEST ~~~ #13
DUH.. I wasnt thinking that way. But I see what you mean..
Brian
   / ~~~ WHAT"S BEST ~~~ #14
How funny! I logged on today to post this very same question. Personally, im going for a deckover for the DOA machinery i have to trailer. Did you decide on the type of ramps? Fold up or slide in?
I'm thinking tilt bed on a deck over .
This would eliminate ramps and make loading easier I think.
What inspired me to start this thread is I bought an 8 x 10 storage building and realized you could not get it on the lower trailer with the wheels beside the bed rather than under it.
   / ~~~ WHAT"S BEST ~~~ #17
With the tilt bed deck-over keep in mind the angle of approach to determine if any attachments might drag. For my backhoe, I just lift the stick to clear, but since it's 3 point attached, the thing hangs low underneth as well and I have dragged that part too.
L . B .
It's starting to look like it takes a roll back to haul tractors and small buildings both.
L . B .
   / ~~~ WHAT"S BEST ~~~ #19
Those tilts look great but if you want to trailer multiple items it will be a problem. So many choices. Im doing my homework on this purchase, as you are. Im trying to avoid the "i shoulda got .....".
http://inlinethumb37.webshots.com/5860/2397855230060323780S600x600Q85.jpg
Why would attachments be any more inclined to drag on this trailer than a ramp type trailer?
Also could you not use ramps on a tilt bed deck-over if or as required?
Why would hauling multiple items on a tilt bed be any more of a problem than hauling them on a trailer with ramps?
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
Club Car 4x4 Diesel Utility Cart (A59228)
Club Car 4x4...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
