What size bush hog for the 2320 guys ?
   / What size bush hog for the 2320 guys ? #21
I have a D-15 Allis which is 45hp plus and a 6' Brush Hog. Im heavy grass its all the tractor wants in second gear. I have no idea how 23 hp would swing a 5' model. Maybe if you had a very poor grade of weeds or grass 4-5 inches tall. Incidently the blades were sharpened recently.. It just takes brute pto hp to spin the cutter especially in damp to wet grass.
   / What size bush hog for the 2320 guys ? #22
I'm also one promoting the 5' cutter. My old 670 with 16.5 PTO HP did fine with a 5' Land Pride (which I still have).
Tall thick stuff will be slow going, but slow going is a good idea in tall thick brush no matter how big the tractor. There will be times you'll need to make a partial width pass....and there'll be areas you can use the full width of the cutter.
There ya go...my recommendation...worth every penny you paid for it.
   / What size bush hog for the 2320 guys ? #23
2320 has like 10+ LESS Ft. Lbs of torque than my 2520, and I would not be able to cut what I do with this 5 foot flail if I was that far down on power.
If you cut short soft grass, the 5 footer is great, but if you are going to cut tall thick damp grass weeds, its gonna get annoying going turtle pace.
The 5 footer does cut ALOT better than the 4 footer, because the blades are soo much longer and the ends have more blade speed. LOVE my 5 footer, just not sure if you can turn it......
   / What size bush hog for the 2320 guys ? #24
Interesting point.
Blade speeds as posted on Woods web site:
48" = 13,028 fpm @ 540 rpm
54" = 14,657 fpm @ 540 rpm
60" = 14,335 fpm @ 540 rpm
72" = 14,962 fpm @ 540 rpm
Love my HC54. Weighs in under 500lbs, and cuts more like a 5 footer. Of course, the blade is only 3/8" thick instead of 1/2", but it pulls very nicely and is recommended for 15-40 PTO hp, so I don't think the 2320 @ 18 PTO hp would have any problem.
Joe
   / What size bush hog for the 2320 guys ? #25
Actually Rob if you go to the JD spec sheet, the LX5 HP rating says "Minimum 18HP" and the cutter weighs in at 520lbs, so it's right in line with a 2320 when used properly. I, for example make sure that it doesn't bounce around on the 3 point and use the transport wheel to take some weight off.
Although I did see in the Frontier specs that JD upped the HP rating to 20 for the RC 2060 since it weighs a whole 70lbs more.......
I think the HP is right on the end of what's required. The problem for me is the 3PH.
I think it's rated at 1250 or so at the end of the lift arms so if you figure a 5 foot hog has its center of balance around 2-1/2 to 3 feet past that you're putting a weight of between 2.5 x 520 = 1300 lbs; 3 x 520 = 1560 lbs. and I think this is more than the 2320 can handle especially when you consider it comes in at about 1600 lbs or a little more if you leave on the FEL.
Rob
   / What size bush hog for the 2320 guys ? #26
I think we are missing something here. Applying the 5 Hp/ ft rule is based on the full power developed. Running the engine to turn the PTO at 540 rpm also puts the available engine power at 65-80 % and on a low Hp tractor you will be under powered. 25 x 65% = 16 hp, that is going to be hard on things.
   / What size bush hog for the 2320 guys ? #27
Sounds right to me too Transit, also my Woods HC60 (5 footer) comes in at over 600 lbs. I'm not sure what the Frontier's come in at but the HC60 is not considered a 'heavery duty' bush hog which I thought was about equal to the Frontier.
Rob
   / What size bush hog for the 2320 guys ? #28
I think you're missing the tractor's PTO HP rating and basing your post upon the gross engine HP. The PTO HP is measured at PTO speed (but look at the tractor's specs anyway since the marketing departments may fudge a bit).
There is no hard and fast "rule" about 5 HP per foot of width. That's just a guideline that's been kicked around for many years. I used a 5' cutter with a 16.5 PTO HP tractor quite successfully. The Kubota dealer that sold me the cutter frequently sold them for use with B7500 tractors too.
   / What size bush hog for the 2320 guys ? #29
I haven't missed anything, as you say,
'it is a guide" just adding more refinement. Can you tackle 5 ft high grass or brush with 16 hp? Same cutter with 30-50 hp is no problem.
This is the stuff that makes for horse races. :)
Question; how much can a FEL lift if the lifting force is 3,500 lb at the end of the lift arm?
   / What size bush hog for the 2320 guys ? #30
When I first mowed the right of way (with the 60" cutter and 16.5 PTO HP), most of the brush was as tall as the cowl (about 48", I'd guess) and some as tall as the ROPS. Slow going (which since I didn't know what was under the brush, slow going was the rule anyway...even if I had been running a bigger tractor), but the tractor/cutter did fine. There was an occasional bogging, but not too much of that. It actually surprised me how well it did.
BTW, Land Pride's recommendation for the cutter was 20 PTO HP, minimum. By Land Pride's requirements, that's 4 PTO HP per foot of width (for a standard duty cutter...I don't think Land Pride manufactures light duty equipment).
So, in answer to your question "Can you tackle 5 ft high grass or brush with 16 hp?", the answer is "I did" (others might not have done as well, or may do better).
As far as the HP calculation....PTO HP is measured (or calculated) at PTO speed. I'm not sure how you came up with 65-80% since that HP curve is quite dependent upon a number of variables (cam profile being a biggie).
That old 670 (tractor described in my posts) developed 19 gross engine HP, 16.5 at the PTO. That's about 87%. My 4400 develops 35 Engine HP, 30 PTO HP...that comes to about 86%. I'm rounding the percentages, of course.
I'm not even sure where you came up with "Applying the 5 Hp/ ft rule is based on the full power developed". Never read that that "rule" other then as a subjective comment or guideline on TBN.
As far as "Question; how much can a FEL lift if the lifting force is 3,500 lb at the end of the lift arm?"...can't help you there. My engineering books are at work and my math is too rusty any more.
2025 Auger Skid Steer Attachment (A53421)
2025 Auger Skid...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
