What size Disc harrow to buy?
   / What size Disc harrow to buy? #1
sclearman
Kaufman Texas
New Holland Workmaster 35 (LS g3033)
I'm getting some very varied and confusing advice from a few different places. I need/want to buy a disc harrow for my place to open the ground a bit, knock out the grass and get things ready for putting in food plots. I have about 10 acres that I need to disc.
My question comes in with which disc to get. I use a New Holland Workmaster 35 (LS g3033). I have been told that it will handle pulling a 10' travel disc, that it won't be able to pull over a 4' 3point disc, that it will pull a 3point disc up to 6', and that it will pull a 3point 6 1/2' disc but only a light weight angle iron frame, not a box frame heavy disc.
I hope you can understand that it's confusing.
So, I'm asking advice, hopefully from folks who have the same or similar tractor. What size/weight disc will this tractor handle? My soil is mostly soft sandy loam, with a bit more clay in the mix in the lower area. I have no rocks, but do have a few roots left from where the mesquite trees were pushed up.
I have looked at the County Line 6 1/2' disc at Tractor Supply CountyLine® Heavy-Duty Disc, 6-1/2 ft. Cutting Path - Tractor Supply Co. .
I am going back to the tractor house to look at their disc, which is a heavy angle iron frame.
I'm open to advice.
   / What size Disc harrow to buy? #2
Your tractor might pull those disks in non-plowed ground but I promise you it won't when you go to disk it next time. I would go no larger then a 5' square tubed frame disk with notched blades that is easily adjustable. Sandy soil is tough to pull through trust me. Look at everything attachments. They have nice disks. You don't want to bother with angle iron disks, no weight.
   / What size Disc harrow to buy? #3
Oh and also get one with sealed bearings.
   / What size Disc harrow to buy? #4
I have an 8 foot boxed frame fairly heavy disc and my LSP7010 has to be in 4 WD to pull it in fairly loose soil. It isn't a problem for a 35 HP tractor to pull one that wide (8 foot) in very hard ground but after a couple of loosening up passes, you wouldn't want anything wider than 5 1/2 feet.
OH and a 3 PH disc pulls easier than a drag type, that is one that hooks to the drawbar and uses wheels raised by a hydraulic cylinder to raise and lower. (travel disc as you called it). A travel disk usually cuts better than a 3 PH style also.
   / What size Disc harrow to buy? #5
One thing you didn't mention is what kind of tires you have. AG tires(R1) will pull more than Industrial (R4)
Sorry, yes they are Ag (R1) tires. and of course it is 4 wheel drive.
I forgot to mention, the dealer where we got the tractor is bringing in a disc for me to look at. He says it is a heavy angle iron frame, like 3/8' angle. A smaller version he did have in stock appeared to have bushings for bearings, they looked like pvc pipe cut and used as a bushing. I'm pretty sure I want to stay away from that.
Thanks, that is an excellent write up. comments after the write up kind of muddy the water again. I'm trying to reconcile the 5hp/foot of disc. By that, the workmaster 35 with 33 hp should handle a 6-6 1/2' disc fine. However several folks here have said it wont. In fact on the New Holland web sight the list a disc of 70", double gang box frame specifically to work with the tractor Attachments-and-Loaders-Compact-Tractors New Holland disk-harrows - Models, technical data and characteristics
But the New Holland dealer where we bought the tractor doesnt carry that exact disc, and of the similar ones he does have he said they are too heavy for the tractor.
really wish I could find someone with that tractor, or a 'try before you buy' dealer.
   / What size Disc harrow to buy? #10
You are kind of missing the point.
The important dimension is the disc diameter = weight per disc.
Width of disc gangs varies depending on how aggressively gangs are set by operator. More aggressive = less width. Perfectly "straight" = max width. So there is no "one" width.
The Disc you provided a link to seems like it is a 20/16", 7-1/2" disc spacing, at any rate 678 pounds/20 = 33.9 pounds per disc.
This disc will do fine, reducing plow furrows. For acting "sort of" like a plow, or "sort of" like a tiller, it is too light.
I would look for a 16/18", 9" disc spacing, or a 16/20", 9" disc spacing, for food plots.
If your Disc Harrow begins to slow the tractor's forward motion, you lift the three point hitch. Usually, 1" of lift is enough to reduce Disc Harrow draft force and maintain tractor speed.
You have to get used to muddy-water/diverse-opinions here.
DO YOU HAVE A FEL OR FRONT WEIGHTS ON YOUR TRACTOR?
   / What size Disc harrow to buy? #11
Countyline Disc Harrow is a 20/18", nothing wrong with that for smoothing plow furrows
For Food Plots you want a 16/18" or 16/20" so you have enough weight bearing on each disc to cut through surface vegetation. Under 40 pounds per disc will not cut it. There is no angle-iron frame Disc Harrow that will even approach 40 pounds per disc. Forget angle-iron frame Disc Harrows; they are for gardeners with regularly worked soil.
   / What size Disc harrow to buy? #12
Here's what I have learned..
I use a chisel plow, 3 pt hitch, on undisturbed soil to begin breaking it up. I go up and down one way all across the field. Then, attack it at a different angle, maybe 45 degrees off from the first pass. Then come back a third time at about 45 degrees from yet a different angle. This goes deep and you are left with chunks of dirt held together by grass/roots. Only with the third pass do I feel that I'm making good progress.
Then, I use a disk plow, pull type, with 2 wheels hydraulically operated to smooth things down and do the final breaking up. Angle of attack, weight and width of this disk affects how much horsepower is needed to pull it, along with type of soil. I find that a wider disk is best for me....if things get tough to pull, just lift the disk a tad with the hydraulically operated wheels and you are off again. If, after a while, you decide that the disk is too wide for your tractor, you can always remove the outer disk on each gang, thus making it narrower and reducing the pull required. The pull disk does a far better job for me than a 3 pt hitch disk...more weight per disk.
If you don't want to purchase two implements, then multiple passes with the disk, as indicated with numerous passes at an angle from the previous one, will get the job done. It also helps to have a gentle rain between each pass to help break clods up. However, lately in Central Texas we don't get rain.
   / What size Disc harrow to buy? #13
I think I am beginning to understand.
Yes I have a front end loader on the tractor, no other weights so far.
Let me make sure I understand....
assuming the same size frame with adjustable gangs, 6' for example (which will adjust wider or slimmer depending on gang angle) the set with 16 18" discs will cut better and deeper because of the weight on each disc, and should pull easier because of less surface area going through the soil? Even though it may 'cover' the same width?
   / What size Disc harrow to buy? #15
I have a disc exactly like the Countyline shown in the thread you posted.
On top of it I have 4 ford wheel weights for a total of about 300#. I pull it with my 1965 Ford 3000 that is somewhere around 35 engine hp. I run the discs set at about mid position and let them seek their own level....3pt is all the way down.
My soil is Houston Black Clay. The disc is not the primary soil breaker. I come in first with something like the Hay King Pasture Renovator to dig down deep with minimum surface disturbance. Then I come back with this disc and work an x pattern.
I have the 6 speed Ford tranny which is 3 hi, 3 lo range gears. I run the disc in hi-1, essentially 4th gear out of 6 at PTO rpms. The disc works better if you move it at a good clip. I have the engine rpms up around PTO when I start a new run and drop the disc. Works just fine for me. I have a camera and the disc is on the tractor currently so if it keeps me from being called a liar, which some do from time to time, I can post a picture. But it will take some effort in getting the camera card setup for a pic on here.
I just went out to verify the actual weight of the 4 weights and realized I took the disc off as I was finished with the current usage. However, I have nothing to do today and I have a new card in my camera so I will go out and take a couple of pictures to support my claims.
Edit #2. Just so I keep things straight, I used my 6530 to pull the Hay King, obviously too much for the 3000.
I put in a longer set of rear axles in the disc to add a flipper disc on the end. Since the tractor's tire spacing was just inside the width of the disc, when the ground was damp I would get my tires gummed up with the overthrow from the plow into the next row. The added smaller diameter discs flip it back in the plowed area.
Mark
   / What size Disc harrow to buy? #16
Texasmark, I believe you
I have houston black clay and have covered my 3ph disk with rocks...at least 300 lbs...as well.
   / What size Disc harrow to buy? #17
Thanks John. I just got them posted.
Mark
   / What size Disc harrow to buy? #18
Mark
   / What size Disc harrow to buy? #19
assuming the same size frame with adjustable gangs, 6' for example (which will adjust wider or slimmer depending on gang angle) the set with 16/18" discs will cut better and deeper because of the weight on each disc, and should pull easier because of less surface area going through the soil? Even though it may 'cover' the same width?
== YES ==
I do not own a Disc Harrow from Everythingattachments.com. I own several other implements from ETA, they are very good quality. I like the screw adjusting gangs on the ETA Disc Harrows.
As you have an FEL you will not need front weights. If front is light, scoop up some dirt in FEL bucket. VOILA!
   / What size Disc harrow to buy? #20
My $0.02:
I have 29hp at the PTO on a Kubota L355SS w/ FEL. I have an older set of discs, about 6 1/2-7' wide & probably weights 700lb or so. I have no problems in 2wd. It used to spin the tires a bit before ballasting my rear tires. They are notched discs & seem to dig in quite well, though running the middle buster first in virgin soil definitely helps.
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A60432)
UNUSED RAYTREE...
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A60432)
UNUSED FUTURE 24"...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
EZ loader trailer (A56857)
EZ loader trailer...
