cbrake
do those landplanes have lift wheels?
No lift wheels: BEFCO - Products - Ground Engage Equipment - Grading Scrapers
I'd go with the 6', and add a couple hundred pounds of weight to the front if needed. Once on the driveway you'll be mainly floating it so it will not be an issue except going up that steep part.
Edit: I should have asked... are your tires filled? I'm used to my 850 with filled tires and it is a beast. I think without filled tires you might lose traction at times with a full load.
I have 5' land plane that I use on my B7610. I thought about getting the 6' but am glad that I didn't. The 5' covers my tires, but the tractor definitely works when it loads up with gravel. I usually end up filling my bucket with all the larger stones for extra ballast & pulling power in 4WD.
With my current wheel configuration, the outside of the back wheels is 5' - 9"
