RollingsFarms
Veteran Member
- Joined
- Mar 26, 2007
- Messages
- 2,298
- Location
- South Carolina
- Tractor
- Few John Deere's and one Ford 3600 diesel.
thanks for all the replys so far! the disk in question was acctually built to the specifications by Hardee to be used by the South Carolina Forestry Commission back in the mid 70's and was purchased at a farm auction by a local farmer. So it's not acommon disk you can just run out and buy at your local implements dealer i wouldnt think. He never worked with the disk because he never had the right tractor to pull it with (most of his tractors didn't have 3 point hitches *large crop tractors*). He just liked the uniqeness of the disk. My grandfather baught it from him in 1982(have no idea of the ammount). I have had several people offer to buy it from me, but have refused simply because I don't think I ould come accross another peice of equipment I REALLY needed like this disk. I asked my forester who does control burns once a year among other things to my farm and he thought it might have been pulled by an old 60-70hp tractor as well. He guessed the weight of it and estimated it to be 900+ lbs. because of its inteded use. Before control burning, they bring down a small 'dozer to make firebreaks throughout the section of woods they are getting ready to burn and my disk measures out perfectly to the width the 'dozer cuts. The only difference is the 'dozer makes a slight trench in the ground, pushing dirt out on the sides measuring about half a foot whereas my disk pilles the dirt up in the middle of the break. The width is perfect and yes its effective, just as long as you keep them clear. This is coming directly from the SC Forestry Commision and they have advised me to not get rid of the disk but if i preferred to buy another disk for other tasks to do so, as long as I keep my current one. I will be ok with just one disk, so I'm only looking for a tractor and bushhog. My 27 hp 950 will pull it, but I can't set it too deep and even then it still bogs it down quite frequently, also I have 250lbs of weight on the front(the max you can get for this size tractor) and it makes the front end dance around and very light(hard to turn...makes the front end want to slide forwards instead of biting and turning). If you 'pop' the clutch too fast you will stand the tractor straight up and the disk will bounce off the ground(I dont suggest this.haha). As I said, my friend admitted that his 5105 2WD knew it was back there when he pulled it so I'm thinking i might can get by with a 5105/5205 as long as its 4WD, but id rather have more then enough tractor then to just be getting by....not to say I want to go too big though because size of the tractor does matter when youre in the woods and having to make sharp turns with trees all around. Alot of things are coming into play, thats why I asked for everyones advice.
I welcome all models and makes that anyone has to offer so that I can research the tractor you suggest I consider. thanks!
