What slippery prod to put on screw thingie on trac
   / What slippery prod to put on screw thingie on trac #31
I would think that even some olive oil might help lube it a bit, gasoline will dry it up and make it hard to turn. Any kind of oil will add some lubrication.
   / What slippery prod to put on screw thingie on trac #32
Rox,sometimes when tilling you might run over a rock or something that will bend the threads over on the adjusting rods. If you take them apart and clean as mentioned and then check for bent over threads and file straight if needed.It has helped me a couple times.Dixy1dog
   / What slippery prod to put on screw thingie on trac #33
ROX,
Welcome to the forum. I was born in France while my Dad was in the U.S. Army. Born in Thierville, De La Meuse.
From the little bit we could see of your tractor, it looks like the whole thing needs a good cleaning and lubricating! /forums/images/graemlins/laugh.gif
Y'all really need to grease up that turnbuckle. If you don't, it will get even worse than before.
Please, please, don't let hubby stand between implement and tractor!!!!!! Not only will it be bad if he gets hurt, but then you'll be blaming yourself forever. First get the tractor as close as possible and hook up whichever side of the 3ph you can. Then use the turnbuckle to get the other side in position.
Replace that pallet/wheel ASAP!
Are there other farmers around y'all? Ask them for ideas on making the hookup easier. It's kinda hard for us to make recommendations without being able to see it.
If y'all will post some pictures of all those other implements over in the attachments forum, we can identify them for you.
Your hubby is a lucky man. Good luck.
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
