What to buy to pull things with? rope? chain?
   / What to buy to pull things with? rope? chain? #51
Chain is usually OK for a moderate jerk if you have something flexible in the line to absorb the shock - in your case, NewToy, vines :D
Charlie
   / What to buy to pull things with? rope? chain? #52
An old tire in between two chains is a great shock absorber! (what else can you do with old tires these days)
   / What to buy to pull things with? rope? chain? #53
Interesting thread on log skidding. Only a couple of mentions of snatch
blocks I see.
I often need to skid logs out of my creek and I use chains when they
are nearby, but I use 3/8 galv cable for the long pulls. I have a 100-foot
one and a 50-footer. Snatch blocks are needed to re-direct the pull
direction, and they work ONLY with cable. I try not to do any jerking.
I hired pro loggers years ago and they used a skidding machine that had
a winch that could pull a 120-ft douglas fir from well over 100 feet away.
It was most impressive to watch.
   / What to buy to pull things with? rope? chain? #54
It all boils down to thinking about what you are trying to do. If you are towing a similar sized vehicle out of a ditch, mud or snow, then a snatch strap will probably be best. If you are trying to break small roots free then a chain to give a quick jerk, but expect it to fly if you jerk too hard. If you are trying to drag a heavy vehicle (or load) up an embankment, then use a winch and snatch-block. You need different equipment to do different jobs, but what ever you choose, make sure it is strong enough for the purpose and think about where it will fly if something breaks.
Unless you are trying to break something such as roots, then a smooth pull with gradually increasing force will normally do the job. This might be slowly tightening up the winch cable or quickly jerking on a 1" nylon tow rope. Either way its a smooth force being gradually applied, not jerking on a steel chain....
When using nylon make sure that you are not pulling on a sharp edge and always make sure that you are fastened to someplace solid, not steering members or a light duty trailer hitch....
If you feel that the load should be moving but doesn't, then find out why before you pull harder. I watched a wrecker rip the rear axle out of a minivan one day because he didn't realize that it was hooked over a stump....
2015 Ford F-350XL (A53314)
2015 Ford F-350XL...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
378253 (A54865)
378253 (A54865)
2014 Ford F-550XL (A53314)
2014 Ford F-550XL...
New Swict 66" Skidloader Bucket (A50775)
New Swict 66"...
Giyi Log splitter (A53316)
Giyi Log splitter...
