herd
Run some 3/4'' pvc thru the wall edge going out in case you want to ever run an air line out to another building. Ditto for possible electrical going back out.I am having a 50x50 shop being built. They have the forms set. I already put in the pipes for a future toilet and sink and ran a conduit for the lectrical coming in. Any thing else I should consider putting in before they pour the slab?
Someone mentioned termite pre-treat. I cannot stress how important this is, esp in the South. Pre-treat and then lay in poly for your vapor barrier. Use 4000# concrete with wire and not #000# with fibre. The cost will end up about the same and the wire is much stronger (and less aggravating) than the fiber.
If your contractor has not already done so, dig out the perimeter to at least 8'', that way washing/eroding won't be a problem and it will look much better. Are you rebarring the footers?
Use keyways every 12' for expansion and anywhere your form takes a turn or changes directions. Otherwise, I can guarantee your concrete will crack. You cannot stop concrete from cracking, but you can control it.
Do not leave any wood or other debris in the foundation that can rot and become a void. Of course, tamping also prior to pouring is a must.
