What to use to lubricate 3PH ball ends?
   / What to use to lubricate 3PH ball ends? #11
My JD manual says use clean motor oil. Never did like that idea. Thoughts on this thread make more sense to me. I've just used WD-40, but it sounds like there's plenty of good alternatives.
OkieG
   / What to use to lubricate 3PH ball ends? #12
I lubricate them once a year with standard grease. Someone mentioned that this helps trap dirt..and I guess it does...but it doesn't wash off as easily as something like WD-40 which would require me to lubricate monthly.
   / What to use to lubricate 3PH ball ends? #14
From reading all these posts, I'm sure few will condone mine. I use used motor oil.
   / What to use to lubricate 3PH ball ends? #15
Synco SuperLube aerosol is a synthetic base with Teflon added. It penetrates and sheds water for many weeks and will not harm paint or rubber. JD private labels the product now. Lowes is the cheapest place to purchase it; they sell a can for $2.99. I've been using Synco's aerosol, gel and grease for more than a decade and have been extremely pleased. SuperLube will not dissolve rust like PB Blaster or Kroil, but you can use those products first and wipe them off with a paper towel before applying SuperLube. Many other products would work, but I like the results.
   / What to use to lubricate 3PH ball ends? #16
</font><font color="blue" class="small">( From reading all these posts, I'm sure few will condone mine. I use used motor oil. )</font>
At least you ain't pouring it on the ground.
Daryl
Forage Services L.P.
   / What to use to lubricate 3PH ball ends? #17
After reading these posts I got to thinking. I had a can of something called a "high pressure" lubricant in my garage. Never really had a use for it. Took it out to the tractor and sprayed it on the balls. Looks like black paint. Doesn't penetrate like an oil would. I'll use it till gone then maybe switch to something else. The oil is kind of messy and attracts dirt.
Terms and Conditions (A47477)
Terms and...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2020 KUBOTA RTV...
2007 FORD F150 XL TRUCK (A51406)
2007 FORD F150 XL...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
