What tools could you not live without?
   / What tools could you not live without? #21
A large sized filter wrench. I had to go buy one last time I changed the oil because the old screwdriver through the filter trick didn't work.
Really, a set of wrenches, sockets, grease gun, large cresent wrench, and you should be good to go.
One thing I've found VERY useful that is a tool and I use with my tractor (but not for maintenance) is a 6' - 17lb pry bar that I use to hook up my 3 point implements. It is SO much easier than trying to lift or push something into place by hand.
FWIW, Nathan
   / What tools could you not live without? #22
For tractor/vehicle maintenance: 5hp Devilbis air compressor.
For everything else: 18V Dewalt cordless drill / sawzall / circular saw kit & 3 batteries.
   / What tools could you not live without? #23
I keep my gease gun and air compressor in the shop, so they wouldn't count as tools that I keep on my tractor.
On the tractor I like to have a hammer to help persuade implements on. I also like to have a few open end wrenches to tighten up my linkage.
For emergancies while operating, I have an adjustable wrench, adjustable plyers, philips screwdriver and a flat screwdriver. I also keep extra pins and sheer bolts and a roll of toilet paper.
Anther important thing to keep with you is a small icechest. Mine is bolted onto my fender and I keep water or some other drinks in it.
On my steering wheel I have an old casio waterproof watch. No other use for it, but it's real handy on the spokes of the steering wheel.
Add a broad brimmed hat to the list and you have the tools I can't live without. Not one, but not allot either.
Eddie
   / What tools could you not live without? #24
A set of the prismatic jaw Vise Grips. The V shaped jaw of the 10LW will hold nuts from 9/16 to about 2" well enuf for you to stand on the handle. It clamps well on rounds without marring. Use it as a hammer in a pinch. Tip for smaller nuts. Cuts wire. Clamp one to a 1" hex on the tractor and forget it til you need it.
Larry
   / What tools could you not live without? #25
B.F.H. and a pair of Vise grips /forums/images/graemlins/grin.gif
btw why is it called a pair /forums/images/graemlins/confused.gif
   / What tools could you not live without? #26
The ones in my neighbours garge! /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
   / What tools could you not live without? #27
My Leatherman !!!
Solo
I'm taking notes here... pry bar... grease gun... toilet paper ( good one)... I can see I'm going to need a bigger tool box.
   / What tools could you not live without? #29
There was a post not too long ago about "What do you carry in your Tool Box" or something that...Anybody remember that one? Anyway, you couldn't believe what some of these jokers keep in their tool box(es) mounted on the tractor. Quite entertaining and informative....worth a search.
   / What tools could you not live without? #30
Rob,
The only thing I remember about the thread was the sanitary pads that were kept in the tool box to stop the bleeding in case of a serious injury. For some reason that stood out.
Farwell
2013 Ford F550 Bucket Truck with Terex Hi Ranger HR37M Boom (A55218)
2013 Ford F550...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
