What tractor are you using in your vineyard?
   / What tractor are you using in your vineyard? #21
This is the tractor I have been running the past couple days. My friendss JD 5310N. The tractor pulling the other cart is a NH TN75V
   / What tractor are you using in your vineyard? #22
I have blackberries and blueberries on 12 ft. rows. They grow out about 2 ft. so that makes it 8 ft. to get down. I use a Fendt 209P that I purchased used in Michigan. It is about 5 ft wide with tires on the narrowest settings. It works good. I use a 7 ft. mower.
   / What tractor are you using in your vineyard? #23
My vineyard tractor is a SAME, it's been a good tractor... I believe it will go down to 48" wide, although I keep it wider.
You may want to see if you have a SAME dealer...
SR
   / What tractor are you using in your vineyard? #24
Can you post some pics of your fendt including the operators platform?
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2009 Ford Econoline Wagon Van, 101,671 Miles (A56438)
2009 Ford...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
John Deere 5075E (A53317)
John Deere 5075E...
