what tractor do you tow with compact truck?
   / what tractor do you tow with compact truck? #11
mrtractor, that's just too funny.
I want to start a thread about what compact truck do you pull with your tractor? I've pulled a few and some larger ones too.
John
   / what tractor do you tow with compact truck? #12
A MF-135 weighs roughly 3500-3800 lbs. depending on various things.
   / what tractor do you tow with compact truck? #14
What truck?
   / what tractor do you tow with compact truck? #15
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / what tractor do you tow with compact truck? #16
I have towed my L3000 with 6' mower on a 16' tandem trailer behind a Ford Ranger with 3.0 V6.
Thank God I wasn't going far.
I don't think the truck liked it any better than I did. The clutches and transmissions in these little trucks are flimsy. I can see them not lasting long if you tow very often.
   / what tractor do you tow with compact truck? #17
Geeeezus, what the F!?! Where are the DOT load and balance police when idiots like that are roaming the streets???
   / what tractor do you tow with compact truck? #18
This is a seriously STUPID forum, so much so I just can't hold my typing fingers back any longer.
You should NOT tow any trailer rated for holding a tractor with a 'compact truck'.
Little trucks are for little jobs.
Get a truck that is designed for this type of job.
Your life, your truck's life, and every else driving around you is affected by your decisions.
Exercise responsibility and do the right thing here boys and girls.
   / what tractor do you tow with compact truck? #19
I believe some compacts are rated for towing tractors. Especially with tow packages, you would be surprised what weight they can tow. Many small trucks are lighter, not lighter duty. Don't be fooled by the "size" /forums/images/graemlins/smirk.gif. My friend works in a pit and tells me all the time how toyotas and nissans can carry more than a full size 1/2 ton truck. I understand weight issues, but you made reference to "small truck = small job" Not always true unless you are comparing to 3/4 ton.
   / what tractor do you tow with compact truck? #20
</font><font color="blue" class="small">(
Exercise responsibility and do the right thing here boys and girls. )</font>
Seems someone really believes that size does matter... /forums/images/graemlins/wink.gif
My Dakota is rated to tow 6750 lbs, or roughly 1.5 times its own weight -- and has virtually identical towing capacity to the Ram 1500 which appears to be a much bigger, more capable truck...
But, then a Dakota is truly a mid-size and not a compact, either...
2003 650 Kawasaki (A53314)
2003 650 Kawasaki...
CAT 315 Bucket Cylinder (A54865)
CAT 315 Bucket...
2012 Ford F-150 Crew Cab Pickup Truck (A55788)
2012 Ford F-150...
Mini Excavator Rake (A53316)
Mini Excavator...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2016 GMC Savana (A53314)
2016 GMC Savana...
