what tractor to buy?
   / what tractor to buy? #21
</font><font color="blue" class="small">( Dave in CT,
That is great advise! Once I get the ponds and driveway built, my requirements will be not be as heavy-duty. This would then allow me to down grade the tractor a little. Great advise for a budget! Thanks again!
Joey )</font>
Thanks...
Consider all the options... choose what's best for you...
Good luck...
Dave...
   / what tractor to buy? #22
</font><font color="blue" class="small">( I brush hog, plow, grade, drag, etc almost daily with a $2500 9n and approximately $1000 of implements. Not that I recommend this for everyone, but I have gotten a lot of work done on a very very tight budget.
Just a different perspective /forums/images/graemlins/crazy.gif in case this fellow does not want a tractor payment. )</font>
Are $2.5K and $1K practical numbers that I can repeat in today's tractor market? Thanks.
   / what tractor to buy? #23
Antique Fords, in servicable condition in my area start at $2000 and probably go up to $4000. Restored old Fords probably start around $3000 and go up to $6500 depending on the quality of the restoration.
The old Fords are plentiful, many are still very strong workers, they are not nearly as convenient as a modern machine, but they are $10,000 less expensive! I had an old Oliver Super 55 Diesel (very similar to the Ford N series) that had less hp than my current Kubota, but in a pulling match would probably yank the new Kubota's frame right off the wheels! Antique iron is a wonderful thing to play with, I don't like working it simply because I'd rather have all the modern conveniences, but it will still get the job done and even I can fix one!
   / what tractor to buy? #24
Yeah dont know about Fla, but that is what i actually paid for my tractor last year...seem to be a lot of ford 9/8N and Massey 35/135 (a little more) which are good utility tractors with ez cheap parts, lots of help on the web...
The nicest thing is that ANY mechanic can work on one of these tractors - most guys will say 'oh I had one of those once..." /forums/images/graemlins/grin.gif
   / what tractor to buy? #25
</font><font color="blue" class="small">( I had an old Oliver Super 55 Diesel (very similar to the Ford N series) that had less hp than my current Kubota, but in a pulling match would probably yank the new Kubota's frame right off the wheels! Antique iron is a wonderful thing to play with, I don't like working it simply because I'd rather have all the modern conveniences, but it will still get the job done and even I can fix one! )</font>
Do you know anything about Oliver 88? Someone is selling one in my area. He said it's running but can take advantage of some valve job and clutch job. I have no idea what that means but if you can shed some light....
SteveM,
Where do I find such tractors? Local tractor dealers? Do these old tractors have 3 point hitch and pto?
Thanks.
   / what tractor to buy? #26
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I had an old Oliver Super 55 Diesel (very similar to the Ford N series) that had less hp than my current Kubota, but in a pulling match would probably yank the new Kubota's frame right off the wheels! Antique iron is a wonderful thing to play with, I don't like working it simply because I'd rather have all the modern conveniences, but it will still get the job done and even I can fix one! )</font>
SteveM,
Thanks. )</font>
The Oliver 88 series tractors were available in several configuration, it is a fairly large tractor and was available in gas or diesel, narrow or wide front. That model would very likely have a 3pt hitch and a rear PTO, but I'm not positive all of the 88's did come so equiped. With old tractors you have to be careful about such things. Ferguson invented the now standard 3pt, it did not become common until the mid-1950's and was most common the the Ford and Ferguson tractors. Allis Chalmers didn't adopt it until much later on. Not sure when Deere, or IH/Farmall adopted it. Oliver put it on the Super series machines in 1954, or there abouts.
A valve job might be a big project or might not.
A clutch job would require breaking the tractor in half to repair and that is a major project.
   / what tractor to buy? #27
It is diesel and 2 front wheels almost touch each other (narrow front?). The owner describes it as a pulling tractor so I suppose it does not have pto? Certainly no 3ph. Must be from the era before the pto/3ph adoption. One more thing. Onwer said it has Oliver 99 engine. I guess I had better stay away from it for all the repair needs. Thanks.
   / what tractor to buy? #28
I would stay away from that if you intend to buy a working tractor.
   / what tractor to buy? #29
Dont wanna scare you but wondering where ya live. out here in Brimfield(should be rockfield) we got alot of big boulders. When we built on our ten acre lot the contractors track hoe rocked back and forth pulling some of the boulders out. Thats a huge machine . As far as doing a foundation you really got tobe good to level it out. The drive could be tricky too, getting it dug out depending on sub soil pitch and culverts for drainage.Now as far as a good tractor a 35hp would be the min. and don't get 2wd if you are going to excavate ponds post holes ect. The Jinma is a good entry level tractor for the buck. Mine was 14,000 for a 35 hp 4wd with fel and a hoe. no syncro in it but the 2 stage clutch for a tiller and draft controll for tilling. The Chinese is the low end entry the kioti is the next folowed by the big three.
   / what tractor to buy? #30
I am new to this "tractor" thing. I currently have a 10 HP Gravely that I bought, new, 20+ years ago and it has served me well. We are moving to a 6.5 acre property, on which my wife will have her horse and barn. The seller let the turf go, so among painting and many other things, I need to get the foot high grass mowed. I will have my shop, to work on cars, metal wood, etc. As much as I would like a USA Deere, I don't think that I can afford one, I was thinking about Kubota or Kioti. Can anyone tell me about these FarmTrac tractors. Where are they made? Other references? My needs are to main/mow the 6.5 acres, move horse poop (FEL), winter plow a driveway, perhaps back hoe (there are drainage issues away from the house, and perhaps dig a dry well for roof runoff, etc. Keeping in mind that I am not experienced in such tractors and actual use, plus my wife must beable to learn to drive the thing (se "cound't/can't drive the Gravely..Hmmm?) Where do I start, keeping in mind that I need to mow the place in a few days. PLEASE HELP
Steve
rbcsaver@ptd.net
regards and thanks.
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
