what weight oil is it?
   / what weight oil is it? #11
Here's the web page:
Hy-Gard
A quick search of the depth of knowledge on TBN itself, showed J20C turned up alot. Here is one thread where alternatives were discussed.
TBN Thread
Cliff
   / what weight oil is it? #12
Hy-Gard
TBN Thread
Cliff
   / what weight oil is it? #13
<font color="blue"> all it says is J20D and J20C, I dont know what that means. I cant believe it does not give a specific weight. </font>
Garrabo,
I don't know if your manual is different but the on-line manual for the 3120 contains this information:
<font color="blue"> Transmission and Hydraulic Oil
IMPORTANT: Avoid damage! Use recommended oil only. Do not use engine oil or "Type F" automatic transmission fluid.
Choose oil viscosity based on the expected air temperature range during the period between oil changes.
John Deere Low Viscosity HY-GARD transmission/hydraulic fluid is recommended. John Deere HY-GARD transmission/hydraulic fluid may also be used for temperatures above -18° C (0° F).
Other oils may be used if they meet John Deere standard JDM J20C or J20D.
</font>
This is located at the very beginning of the section tiltled Service Transmission. There is also a temperature range chart. There are only 2 oil weights. The standard Hy-Gard or the Low Viscosity Hy-Gard which I think corresponds to the J20C and J20D designations. I only know this because I came across the same thing on Saturday for my 4310. I called the dealer and asked him if he had J20C or J20D oil. His response was "Uh?". He asked me what it was for and then told me Hy-Gard. I looked at the manual again and saw that it was spelled out at the beginning of the section but the MFWD section only states J20C or J20D. No reference is made to Hy-Gard.
The dealer should be responsible for flushing and refilling your MFWD with the proper fluid since he gave you incorrect information.
Jeff
   / what weight oil is it? #14
Garrabo,
</font>
Jeff
   / what weight oil is it? #15
<font color="red"> </font> The dealer should be responsible for flushing and refilling your MFWD with the proper fluid since he gave you incorrect information.
Jeff
I like that. Charge people for dumb answers. I wonder if this was adopted as a standard if it would improve the quality of service that consumers have been receiving in recent years.
   / what weight oil is it? #16
Jeff
I have yet to have satisfactory results from a deere dealer in Georgia. It seems they are owned by white collar investors that have the money to buy in but are vacuous themselves by nature and the employees they hire /forums/images/graemlins/crazy.gif
I got it figured out. Amsoil cross referenced it for me. Its the same oil that goes in the tranny not the 75w90 the dealer told me would be ok. Does anyone suspect I would have any damage or concern. I added 3/4 of a quart of 75w90 to the axle to top it off and ran it about an hour. Its actually is a 5-30 fluid that goes in the axle. its the same lube that goes in the tranny. /forums/images/graemlins/crazy.gif
COOLTECH 34288 (A55745)
COOLTECH 34288...
Club Car Utility Cart (A55853)
Club Car Utility...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
