What's it like owning a zero turn?
   / What's it like owning a zero turn? #21
The "name brand" mowers at big box stores are knock-offs. Under license, yes. But knockoffs nonetheless. Consider them as Murray's with trademark paint and decals. My JD dealer says they only permit this if/when the big box store store agrees to use John Deere trained assemblers. Otherwise, JD won't honor the warranty. I don't doubt other legitimate mower manufacturers have similar stipulations
If you only have $2500 to spend, save the extra money charged for the green and yellow paint job - and just buy a a Murray or equivalent 2nd or 3rd tier mower
But to your ZTR question: I spent $5500 on a first tier zero turn, and returned it for a refund after two hours. Without optional tires AND diff lock, it was useless for hillside work. Couldn't hold a straight line downhill, and reversing uphill was absolutely impossible. If you're just mowing flat ground though, a ZTR should be just fine (once you learn to actually make it go where you want it to)
//greg//
Your dealer is flat wrong.
They are the same exact machine, from the same assembly line. My local dealer was a friend of mine. A few years back he sold his dealership to a larger still JD dealer, and went to work as the area liaison between Lowe's and JD. He has been right to the plant to watch them all being built.
Your dealer is not alone in BS'ing folks though. Many do the same thing to help bump their own sales.
Also- A $5500 machine is nowhere near a "first tier" ZTR.
OP-
I have seen a bunch of misinformation in this thread so far regarding ZTR's and what they can or can't do. I run one for a living, and have for a long time. Turning uphill is the correct way to do it on a ZTR so that you keep the weight on the rear where the traction and power comes from. Holding the sticks in full reverse to try to gain traction once you lose it is also incorrect. The best thing is to let off both sticks to stop briefly and then start moving ahead slowly to gain traction again. Once the rear wheels break free, they rarely gain traction again without letting of first.
ZTR's are not the best for holding a hillside. The front being on casters wants to drift down hill, and learning how to combat that takes time if you want to do it safely and correctly.
Anyone wanting to buy one should demo several of them on their own place first.
The single most important thing to learn is where you can and can't go on one, and when. Running one for a few hours per week is not going to give you the seat time you need to learn that, especially when you are only mowing one property with one set of circumstances to deal with.
   / What's it like owning a zero turn? #22
Not everyone can play golf & not everyone can drive a zero turn mower. That is why I suggest that anyone that has never used one, to try one out on there property before buying one.
Excellent advice.
   / What's it like owning a zero turn? #23
I currently have been mowing with my John Deere L130 since 2004. I get worn out with no power steering mowing my 3.5 acres full of trees and obstacles. I'd be content with a new riding mower that has power steering, but they cant be bought for $2500 which is why I'm considering a zero turn. I've always had a traditional tractor style riding mower and never gave a thought to owning a zero turn until now. I'm thinking about buying a new John Deere Zero turn mower from Lowes. I dont want to spend more than $2500.
Based on my experience with the L130 riding mower the additional benefits of a zero turn are:
Zero turn pro's:
- Faster top speed
- Effortless turning
- No front spindles to wear out
- No steering gears to break
- No tie rods to break
- Exhaust is directed out the rear and away from you, no breathing fumes
Cons:
- Ugly, IMHO
What its like owning a zero turn mower? They seem like a simpler machine. Any common problems with them or other pros and cons?
You can look around, but they have 'near zero-turn' tradition lawn tractors now that make life much easier.
   / What's it like owning a zero turn? #24
I have a 'Gizmow' ZTR that has a steering wheel connection via chains to the front wheels. It actually works pretty well, but the fellas that came up with it tried to break into the market right when the 'recession' hit and couldnt do it for very long. It is very, very well built, weighs over 1600lbs and cost $10k new. https://www.google.com/search?q=giz...BAcSwyQGstoC4CQ&ved=0CDQQsAQ&biw=1194&bih=557
Cub Cadet bought the technology and uses it in their RZT-S : RZT S Riders: Check Out These Easy-to-Handle Riding Lawn Mowers
   / What's it like owning a zero turn? #25
I have a 72" JD 997 Diesel and it's a beast. However, my mowing land is more of a field not a smooth lawn so now I use a JD 1600 WAM with 4 wheels. While Z mowers are fast, they are very bumpy because they have no shocks and the design of the wheels right under you. my 997's speed was a waist. I had to go easy or id be reared off the seat. IMO, if you have a smooth lawn you can not beat a Z mower, if you have rough field it does not work that well. I know Ferris makes a z mower with shocks but it will cost you and I don't know how well they work.
   / What's it like owning a zero turn? #26
I paid a little over 8 grand for my Scag Wildcat with a ft deck. I wanted the liquid cooled Kawasaki engine and feel that Scag is about as top of the line as you can get. It has two separate hydraulic drive motors, one for each tire. It has amazing traction and if it's dry out, I just stick to the ground, straight up, straight down, and most importantly, while going along the side of a steep slope. When I come across a street sign, I go from a steep slide slope, to spinning around the sign post, and then back to going along the slope. It's actually kind of fun!!!
Eddie
   / What's it like owning a zero turn? #27
I mowed 4 to 5 acres of grass at the church property in NJ. After having done it with some Sears tractors and belly mowers, I asked them if we could get a zero turn mower. Bought a Scag. HUGE improvement. Those Sears tractors took 5 to 7 hours to mow the grass, having to often make about 4 or 5 passes around the trees to mow the grass around them. Had to use a push mower to trim some other places. With the Scag, it was a 3 hour job with no trimming needed by push mower.
Ralph
Thanks for the replies. While my land is relatively flat there is a small tricky area where my land slopes off the road. The mower flexes hard through here and sometimes will lift a front wheel. I have to be careful not to get stuck. On a 50" wide mower it would take 3 passes 100' long. Also the ground by my pond was roughed up from horses and 4x4's. I once broke the front axle on my L130 running into a hidden rut back there.
I wonder how well the small tires on the front of ZTR's will handle bumps and uneven ground? Also I have noticed many ZTR's do not have an articulating front axle. Is that ever a problem?
   / What's it like owning a zero turn? #29
These are good reasons why I would try to test a ztr on your property before making a decision.
I didn't learn to like mine until my 3rd cutting which wasn't until 10 hours of seat time. I didn't get good ( not great) at slopes until my second season. Its a different driving experience, it takes time to get good at it. Not ten minutes either.
The best thing about my ztr, is it so fun to operate, I fight my wife and oldest son to mow the grass. So that really cut down my mowing time! ;)
   / What's it like owning a zero turn? #30
Well, I actually can't speak for a big box ZTR, I've only owned the Ferris. I was citing what the JD dealer told me about the lawn tractors. For them - all ya gotta do at a big box store is lift the engine cover to see they're not the same engine. Those around here (Lowes) have Briggs engines, including their "top of the line D170. My X500 (purchased at a dealer) has a Kawasaki. And all you have to do is look at the foot pedal arrangement to see they don't have the same transmission either. Plus, diff lock is simply not available on a big box John Deere. No sir, they're not the same lawn tractor. Incorrect as it may turn out to be, I was extending that observation to the big box versus dealer ZTRs.
If you'd return to the context of the OP question, $5500 DOES buy you a first tier residential/consumer grade ZTR. Rather than argue off-topic, let's get back to helping the guy gather his info.
//greg//
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
Land Plane Skid Steer Attachment (A56857)
Land Plane Skid...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
S/A Utility Trailer (A56859)
S/A Utility...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
