what's it worth, JD 2350?
   / what's it worth, JD 2350? #1
terryknight
Easton MD
JD 5055E,Kubota B2650
This tractor (pics at the bottom) belongs to my friend. He is looking to sell it. I may wind up being asked to sell it. It is a very nice, clean, low hour 1986 John Deere 2350. It has 838 hours, 8/4 gear trans, one set of rear remotes, everything works, new front tires, rear at 70-75%. My friend is quite **** about his equipment most seals and hydraulics lines have been replaced in the past 2-3 yrs. It was garaged fro the time he bought it 7ish years ago until 18ish months ago, i don't know about before he got it. He sold his home and the tractor now lives at his sister's, I couldn't believe it was outdoors when i saw it, but his sister doesn't have the space. It comes with a 6ft John Deere grooming mower, a 6ft "bushhog" brand bushhog. and a 6ft rollover blade. He bought it in GA to maintain a grass airstrip. It is now located in MD. It was last used about 6 weeks ago, end Oct. I have looked at Tractorhouse.com and found a range from $6,900 (bottom of the line) - $20,000 (cab and front end loader). It is a clean tractor, however i don't see it bringing $7000 maybe I'm wrong. It doesn't seem to be an in demand tractor to me. Anyway pics:
thoughts? opinions?
   / what's it worth, JD 2350? #2
JD 50 & 55 series utility tractors were some of the best that JD built. Your friends tractor also has the heavier rack & pinion rear cast wheels which was an option. If the hrs are correct it would bring a lot more than $7000 even without a loader down here in Texas. I have a neighbor that's been looking for one.
good to know. hours are correct. you think your neighbor would be interested? i will give you the mans name/number
   / what's it worth, JD 2350? #4
Nice looking tractor good for level land use. Most of the guys today wan't 4x4 but this tractor has enough weight to get a lot done for its hp. The people who are considering a 5000 series D tractor should give this a hard look.
   / what's it worth, JD 2350? #6
If it is mechanically good (good clutch, engine strong and not smoking) I would price it at $11,500 and take $10,000 bottom dollar bare tractor, price the implements separate.
They heavy and stout tractors. With the wheels it has and good ag tires it will make an *** out of same horse power 4x4 smaller tractor when it comes to any kind of tillage / plowing.
I had a 2355 and it was pulling SOB.
   / what's it worth, JD 2350? #7
Also - most of them you see the tins are beat to **** - this one is pristine.
   / what's it worth, JD 2350? #8
These tractors are iconic - I agree with the assessment this tractor was one of the best ever built. I think it is worth $10k as well with those hours. With some work to fit up a new John Deere loader, this tractor is a lifetime purchase. They were beyond their day in durability and a pleasure to drive.
For sure 2wd is going the way of the dodo bird but for a small square baler, hay raking, bush hogging, and many other functions, this tractor is beyond compare for its day.
must be a location thing. i see very few utility sized tractors around this area. most guys are big time farmers with bigger AG tractors, or have little CUTs with 4x4 and a loader. i agree that it will last a lifetime. around here you can go to almost any farm auction and find several 55ish HP diesel tractors 2wd for $3000-4000 grant at that price they are not as clean or with as low hours, but that was where my thinking went
   / what's it worth, JD 2350? #10
Put it on Craigslist over a larger region, used plenty of key words so it gets searched right and somebody will come get it.
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
1993 Generac Olympian 93A 100kVA Towable Diesel Generator (A56857)
1993 Generac...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
Electric tri scooter irgc40 (A56859)
Electric tri...
Black Steel Diamond Plate (A55758)
Black Steel...
