whats the remedy?
   / whats the remedy? #11
here's the BX23 parts diagram and part #'s:
It's vastly different from what came on my BX22.
  • 479787-bx23 airfilter.PDF
   / whats the remedy? #12
for comparison, here's the same diagram/part #'s for the BX22.
  • 479788-bx22 airfilter.PDF
   / whats the remedy? #13
I have a BX1500 and the strap broke with about 25 hours on the tractor. I called the dealer and he sent a new one out with service modification info sheet from Kubota. It is PSB-2003-026 dated June 26, 2003.
It basically involves grinding the sharp edges from the air cleaner bracket.
Seems to have worked so far. But at low idle, that engine sure vibrates.
Rick
   / whats the remedy? #14
Mine just broke a few weeks ago, at around 320 hours give or take. I happened to have some 10 guage aluminum I used for a boat deck laying around. I fabricated a piece of it with the exact same dimensions as the original bracket. Worked perfectly and since it's much thicker I don't think I need to worry about it breaking again.
   / whats the remedy?
what would be a permanent fix? Im sure that new strap I got will break as well. /forums/images/graemlins/frown.gif
1067 (A53342)
1067 (A53342)
More info coming soon! (A50322)
More info coming...
Hose Reel (A53424)
Hose Reel (A53424)
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
American G-Model Pump Jack (A55218)
American G-Model...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
