What's up with my Solenoid?
   / What's up with my Solenoid? #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
This is the 3rd one in 5 years. The tractor starts to behave as though there is water in the fuel. Get on a slope and she acts like she is sputtering. Get level and it seems to stop. She appears to almost want to stall at some point. It will do this for months until I sense I should open the hood and look when it happens and I see the solenoid cutting in and out. Finally she will quit and the tractor will not stop with the key off but I am required to hold the circuit closed.
I know that the under seat electrical tap for the work light option is on the same circuit because I put a waterproof cigarette lighter adaptor in the rear and had a switch from the fuse box at one point and it would have to be one to stop the tractor. I removed the switch from the circuit and left the cigarette lighter adaptor live with the key one. My wiring is all loomed, butt joints greased and tapped and I am sure it is not a short.
Today, I recall the sputtering happened year before last and sure enough, solenoid quit this aft.
Anyone have similar problems? :confused2:
   / What's up with my Solenoid? #2
My tractor would cut out and sputter when going up hill. Was the fuel filters needing replacement. I also had my tractor not wanting to turn off with the key. Problem was I pressure washed my BX24 must have got water in on the solenoid. Used a hair dryer to dry it out and worked fine after that. I did purchase another solenoid to have on hand if the problem arose again.
   / What's up with my Solenoid? #3
BX2230_Lockport, is your solenoid a 2 wire or 3 wire stop solenoid?
Dave
Volfandt:
It is a 2 wire solenoid. Two to the plug, anyway, and then what looks like a single wire to the solenoid, itself.
   / What's up with my Solenoid? #5
Two wire solenoid means it is only energized for the short period of time (usually 10-15 secs) after the key is turned off or one of the safety switches trip. Other than that time frame there shouldn't be an voltage applied to it. The black wire should be ground and the white wire carries the temporary voltage to the solenoid from the timer relay.
internal sping pressure inside the solenoid is what keeps it in the run position and the temporary voltage is what draws it in to kill fuel flow in the injector pump.
With all that said your problem is a very perplexing one. It almost seems as if it's getting a transient voltage from somewhere. That 20 amp fuse that blows actually goes to the timer relay and it's the timer relay that switches 12v to the solenoid. To add alittle more confusion to it, the 20amp voltage is only for the safety switch sensing circuit, it's another 15 amp circuit that actually energizes the solenoid. (per the schematic in my WSM).
Theres only two ways I can see voltage getting to that solenoid in any case besides shutdown and thats either through the timer relay (posibly bad) or a wireing problem.
You say you see the solenoid pulling in/out?
I really don't think the springs are wearing out as I've got around 500 hrs on my BX23 which has the same 2 wire stop solenoid and haven't had a peep of trouble (knock on wood).
I've read of 1 or maybe 2 cases where the timer relay had to be changed out on a BX over the yrs so it's not a very common failure point. At least not on the 2 Kubota forums I visit frequently. So I'd suspect a wireing problem. Possibly a crossed wire or something not wired correctly. Course it could be a bad run of solenoids.
Good luck.
Dave
Thanks for the in depth reply. I have seen the plunger pull in and out sporadically and obviously by electrical current and not spring failure. It would do it twice or thrice over a period of a couple seconds, causing the engine to sputter. Then it would cease. It is odd that I would get a solenoid and it is good for a lengthy time. One might think that if something was shorting out, why would a new solenoid resolve it for, say, 12-18 months, until the same symptoms reemerge, again? That being said, I have the Woods backhoe, which altered the seat safety switch functions, and I have a circuit wired to the factory, under seat, work light power taps that are the same circuit as the solenoid. Seemingly, however , these questions are overridden by the curiosity of a new solenoid immune for a period of time.
Sorry for the late reply. Was away.
   / What's up with my Solenoid? #7
If the quality of the metal in the magnet is of low electromagnet magnetic value or the springs are weaker in their construction -thinner wire guage its a big issue.
   / What's up with my Solenoid? #8
Look for a loose wire or bad switch, as I think the interlock circuit must have continuity to work and when the circuit is broken (seat switch opens) that the timed relay kicks in and energizes the stop solenoid to kill engine.
David Kb7uns
   / What's up with my Solenoid? #9
Just a guess, but if you have a bad ground or sporadic short somewhere in the circuit, it could degrade the solenoid over time until it gets to the point where it starts to malfunction in association with the short.
   / What's up with my Solenoid? #10
I had sputtering problem because of scum/sludge in the fuel tank. The tractor would run fine on flat surfaces then on inclines the junk in the tank would inhibit fuel flow from the tank causing the tractor to sputter and sometimes stall all together. Just a thought.......
2007 Sterling Acterra Dump Truck (A55852)
2007 Sterling...
New/Unused 30in Rolling Service Cart (A54865)
New/Unused 30in...
Informational Lot - Financing (A55314)
Informational Lot...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
2018 RoGator 1100C (A55314)
2018 RoGator 1100C...
