Whats up with this gear oil?
   / Whats up with this gear oil? #11
Interesting, (globs) as I just yesterday transfered the balance of a 5 gal pail into a gallon containet and noticed a glob of something slip thru the funnel.
Have not investigated yet but sure am curious.
   / Whats up with this gear oil? #12
Every gear oil or hydrualic fluid I see looks about like motor oil, maybe a little different color or thickness though. Maybe someone with some more experience can chime in on the globs of stuff.
   / Whats up with this gear oil? #13
looks like could be water globs in it as well... perhaps from setting?
soundguy
   / Whats up with this gear oil? #14
If you hadn't said that was fresh fluid, I would have guessed it was a jar of marmalaid(sp?). I'm just thinking out loud here, but was the fluid defective to start with? Looks like it may have already been defective and that caused the problem. Maybe someone with some more experience will chime in.
   / Whats up with this gear oil? #15
I've never tried it with oils but if you suspicion water in your fuel, even if mixed and not settled, pour a little of red food dye into a container with the suspicious fuel and the red food dye will turn any water, even small drops, red. Whenever I refueled aircraft at smaller airports I'd have the first gallon of fuel sprayed into a clean white plastic bucket and sample for water, especially jet fuel.
Regarding using alcohol in some hydraulic systems, especially those that use MIL-H-5606 hydraulic fluid, alcohol is very bad news!! Even cleaning hydraulic system components with alcohol that has dried and then using MIL-H-5606 Hydraulic Fluid with those components can cause future failures.
Just a FYI
Jim
   / Whats up with this gear oil? #16
Just a FYI
Jim
should be fine in an old tech tractor hyd system using UTF fluid especially.
never had an issue dryoing out a wet sump with it.. had plenty of issues leaving it wet..
soundguy
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
6' SCRAPE BLADE, 3PT (A52708)
6' SCRAPE BLADE...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
1994 SUNDOWNER 4 HORSE GOOSENECK TRAILER (A52708)
1994 SUNDOWNER 4...
PALLET OF PUMP MOTORS & PUMPS (A52708)
PALLET OF PUMP...
